M30 into E30??
godfather
Obviously it can be done... How much of a PITA is it tho? I have an E34 535i at the moment, but would be interested in getting a cheap E30 to do an engine swap. Does it matter which E30 I go for, or can I just get a cheap 316??
Any info greatfully appreciated!!
kam-325i
Best to go for a 6 cylinder chassis, if there is such a thing !!!
Geeman
See this link... perfect base car for your conversion!
http://www.e30zone.co.uk/modules.php?na ... ic&t=20813
Giles.
Giles.
kam-325i
Just the job.......Geeman wrote:See this link... perfect base car for your conversion!
Giles.
all E30 shells are the same I think, with the exception of M3.
Rule of thumb is to get yourself as tidy a car as possible for as little as possible, so a late 316 would be ideal, however the 325 came with the disc brakes on the rear whereas the lesser models had drums, so if you go for a 325 all the morsels will be there but if you get a 316 etc then you will be into repacing rear arms with disc set up plus the front struts etc on 316 are not as large.
Trouble is finding a decent 325 which isn't rotten or costs the earth. All bits are interchangeable though.
- Homo Hair
chassis are the same 4 or 6 pot
325i has all round discs and better suspension/antiroll bar setup
godfather
Cheers for the swift reply guys! So it looks like I could do with a 325 then... That ebay link looks just the ticket... Shame its in Glasgow - I live in Devon!!
I was reading that there are several different options regarding mounting positions... any info on this? Has someone done this conversion, and done a write up about it somewhere.??
kam-325i
Thats the bit i was after !!!!E30BeemerLad wrote:all E30 shells are the same I think, with the exception of M3.
kam-325i
something like www.e30.de i thinkgodfather wrote:Cheers for the swift reply guys! So it looks like I could do with a 325 then... That ebay link looks just the ticket... Shame its in Glasgow - I live in Devon!!
- Homo Hair
Karan on the board can get engine mounts for position 2 or 3
1 is quite far back and requires bulkead modification iirc
Toby_Unna
- Boost Junkie
huh?
1 is all the way forward Dan
don't confuse the bloke, just let him look on e30.de!
Toby_Unna
- Boost Junkie
mr Godfather - two people of the forum have done the conversion as a DIY prospect without spending a fortune - myself and Andy335touring. click on search, there have been a lot of topics on this posted before and i've written it out too many times!
i am however more than happy to help with specific questions!! it's just that this must have been asked ten or fifteen times already!
godfather
Yeah cheers, just found the writeup in english... much easier to understand than the german version!!!
- Homo Hair
shit - wrong way round!!!
i am a dumbass sometimes
godfather
So what works best? I am thinking engine position 2, because of the fact there is little modification to do, and also i can use the radiator from an e32..?
What are you running Toby?
Just how straightforward is this to do? I am not a mechanic, I don't have many tools, or even a workshop... My plan is to get someone else to do the work, I just need to be able to convince them its not going to be a complete PITA...
Andy335Touring
I'm using the E30.de mounts in P3 which i have found out is very close to the postion Alpina used on there B6(M30 powered E30).
I'm not sure how easy the E32 rad is to mount but the E28 535 is very easy.
Theres a few pictures of the swap on here
http://homepage.ntlworld.com/a.law47/33 ... uring.html
ed325i
Does anyone know if you can use a E30 M3 prop shaft when using position 3 ?
ED
ED
bigdek
think its only good for position 1
Andy335Touring
I don't know for sure about the M3 prop and the e30.de mounts on P3 but Toby has an m3 prop on his, his position is some where between 2 and 3 on home made mounts.
I've got the e30.de mounts on P3 but the prop was done by Reco-prop, rear half is E30 front half is E34 M30.
