engine swap
imye30
Post Fri Aug 26, 2011 10:45 pm
320i to 325i first time challenge first place to start an do any help with a list an all the things that need to be disconnect for the engine to be lifted out
leeparkes
Post Sat Aug 27, 2011 3:53 pm
The list is quite long but just undo the obvious.
One part can be overlooked and thats the clutch slave bolted to the side of the gearbox.
When your ready to lift the engine do it slowly and you will see if anything is still connected.
Good luck!
