v12 into e30
dips346
- London Meets Main Man
hi who's done a bmw v12 in to a e30 before, any idea as thinging about toying with one ,need to know how much space around the exhaust side for quad turbos or if not then carbs maybe,main thing first get it in and running first any help thanks
Kos
you are crazy, well and truly in lala land!!
i'll be there ordering pizza and giving a hand with the BIG HAMMER
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
Turbo-Brown
- Boost Junkie
When you say exhaust side, it exits from both sides
You must be made of money if you can afford a sextet of webers too!
I'd go for throttle bodies, better by miles in almost every respect, especially if you factor in the inevitably huge cost of setting up 6 carbs properly!
dips346
you of all people cant be douthing me kos!!! you know who started the turbo bmw crazeKos wrote:you are crazy, well and truly in lala land!!
money is one of those things you have to waste lol
i would like throttle bodies but need to see if it fits first as if it does get turboed than the carbs will be no good anyway
Kedge
Its been done on the continent, think one of the problems i heard of was having no access to the spark plugs when the engine is in. Have a search on e30.de bound to be some info on there!
Good look.
Good look.
tylerma
give me somedips346 wrote:money is one of those things you have to waste lol![]()
i'll gladly waste it for ya
Dan318-is
dips you are well and truly INSANE! thats how we like em
saw your motor at ace last time, completely off the scale mate
bring on the v12 tho, we need more heroes like this!
dips346
someone has to do the conversion but really i do get bored with the same old things very quickly but doesnt mean that what i try to do is right some times my e21 is next on the line then this v12 if i can going to post so e21 pics up soon if the mods dont mind
Kedge
What you doing to the E21? The mods didn't seem to mind when i posted up pics of mine in the pub talk section.
I'm hoping to be putting an M30 into mine but it's starting to look a lot more expensive than i first thought it would
dips346
no done the m30 root already leaving it simple on the engine sideKedge wrote:What you doing to the E21? The mods didn't seem to mind when i posted up pics of mine in the pub talk section.
2.7 with triple carbs with nos
full blown red leather interior with loads of black stich work
chrome cage
9.5 x 15" bbs rear
8.5 x 15"bbs front
few alpina bits
one of body mods
that is so far will start a new post with pics thanks
Kedge
Sweet!
So you've done an M30 into an E21 then?
If you have i'll more than likely be seeking some advice! lol
dips346
not in a e21 but in a e30 i have should be nearly the same amount of workKedge wrote:Sweet!
happy to help if you need it
JoeP
- Location: The Bunge, Waveney Valley, Norfolk/Suffolk border
How about mid mounting it? I've been thinking about doing it to a touring.dips346 wrote:hi who's done a bmw v12 in to a e30 before, any idea as thinging about toying with one ,need to know how much space around the exhaust side for quad turbos or if not then carbs maybe,main thing first get it in and running first any help thanks
Alpine White 325i touring
Saying 'No' to saloon and cabriolet wrongness
dips346
i'am not only the mad one out here then lolJoeP wrote:How about mid mounting it? I've been thinking about doing it to a touring.dips346 wrote:hi who's done a bmw v12 in to a e30 before, any idea as thinging about toying with one ,need to know how much space around the exhaust side for quad turbos or if not then carbs maybe,main thing first get it in and running first any help thanks
hmm makes the mind think some more
JoeP
I think it would be relatively easy, well easier than squeezing it all in the engine bay. I don't have a great deal of knowledge about these things, despite a degree in mechanical engineering. You could have it close to the front seats for weight distribution, the short output straight to the diff with the gearbox on the front, job done.dips346 wrote:i'am not only the mad one out here then lolJoeP wrote:How about mid mounting it? I've been thinking about doing it to a touring.dips346 wrote:hi who's done a bmw v12 in to a e30 before, any idea as thinging about toying with one ,need to know how much space around the exhaust side for quad turbos or if not then carbs maybe,main thing first get it in and running first any help thanks![]()
Dan318-is
u guys r fookin nuts!!!
where du get all this money!
Yes they are sick and thats why they have no money !, except dips, he's caked !
Dan318-is
he sure is!
glenn
- Engine Transplant Services
i think if you measured it up, with the gearbox directly mounted to the diff,
the middle of engine would end up right where the gear stick should be
why not put it in the engine bay, it will fit, it's been done before and i would of thought it'd be easier
Toby_Unna
- Boost Junkie
like glenn i think the engine bay would be a lot lot easierJoeP wrote: I think it would be relatively easy, well easier than squeezing it all in the engine bay. I don't have a great deal of knowledge about these things, despite a degree in mechanical engineering.
people do mid mount engines, but it's generally putting a fwd drivetrain/suspension in the back of a fwd car.
i'm sure mid mounting the v12 would be possible, maybe with a custom transaxle, but putting it in the engine bay would be a walk in the park by comparison.
and in my experience mech eng degrees don't help much with engine swaps!
GermanGorilla
I would suggest you talk with these guys,
www.AKGmotorsports.com
They will more than likely have all the answers.
Regards,
The Gorilla.
Regards,
The Gorilla.
Andy335Touring
944's have a transaxle gearbox/dif type thing,might be worth a look ?
dips346
link does not work,you got a number? thanksGermanGorilla wrote:I would suggest you talk with these guys,
Regards,
The Gorilla.
Kos
true, i'm guilty too !! i wind you up and you me. what happened to me leaving the M3 alone!!!dips346 wrote:you of all people cant be douthing me kos!!! you know who started the turbo bmw crazeKos wrote:you are crazy, well and truly in lala land!!
IG Pukar.Designs
IG Pukar.Designs
GermanGorilla
Try,
AGKmotorspots.com/
Regards,
The Gorilla.
AGKmotorspots.com/
Regards,
The Gorilla.
GermanGorilla
