which clio servo?
whipsey
Whats the one to use from which model? need a few so ones for an m30 m50 and m52 engines
turk
PLastic bumpered clios..
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Sump Baffles
TrackDays
whipsey
any specific engine size or are they al the same?
turk
same i think... If u can find an old Kangoo van they have the same servo as theyre based on the clio too btw.
Sump Baffles
TrackDays
Sump Baffles
TrackDays
whipsey
cheers for the info
vokietis
i'm using clio servo on my 328,and i have a problem with the car starting to brake itself after driving couple of miles...any clues?
You have made the spacer too long
vokietis
DanThe wrote:You have made the spacer too long
