E30 V8 with Rawmotorsport it runs!!! First post with video
Phill172
Post Mon Dec 13, 2010 11:08 am
First start today, just exhaust from manifold back and its ready for Mot tax and hopefully the BDC!
I apologise for my photos and my writing!
Started out with a E30 318 Touring, for me any E30 would do aslong as it was rust free.
So I managed to find this one, its Red :D , no sunroof, and best of all mint
I stuck a M50 in a while ago and used it as my daily runner, but now its being turned into my competition drift/race car.
So first thing was to strip out the engine bay, abs, brake servo, washer fluid bottle and alarm system. Not much as I had taken alot more out when I did the M50 conversion.
Whilst the engine bay was free I replaced the steering rack for a E36 setup as the E30 one is useless, and also fitted a E36 M3 Evo suspension and brakes. Im just waiting for my front coilovers to arrive and Spax coilover units for the rear.
The rear set up is fully polybushed unit from a compact with a 3.38 med case welded diff. Welded because I prefer them they dont open up off power. Alot of people disagree!
For the moment its running mismatched wheels, i am just waiting for a set of 17x8/9 Rota Grids in bmw fitment to arrive.
Engine wise, I bought a E34 540 Manual as a doner car, swapped the gearbox for a 530 5 speed unit (I prefer the ratios) and have bought a billet machined lightweight flywheel and helix have supplied a 5 puk clutch that can handle 600nm of torque, perfect for fourth gear clutch kicking!!
The engine has had a light breath of health with new gaskets, fluid changes and a general service along with a new maf.
That is as far as we have got for the moment! Although today the engine is fitted in with E30.de mounts and I am using Bmw X5 4.4 V8 manifolds
e21Jason
Post Mon Dec 13, 2010 12:37 pm
Very intrested to see how the x5 manifolds work out
Jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
glenn
Engine Transplant Services
Post Mon Dec 13, 2010 4:56 pm
Phill172 wrote:
Brake servo is being fitted under the dash, so no new linkages need to be made altough a simple bracket will do.
this is the route i was thinking of taking phill, with my latest project....hiding it under/behind the dashboard. i'll be watching with intrest :D
Phill172
Post Tue Dec 14, 2010 8:38 am
This is how I will work my setup, bearing mind this is someone elses car and they are using a skyline servo :?
but you get the idea, I may shorten the linkage and bring the servo into the middle of the dash, so I can then remove the panel in the centre console to gain access, and the bracket will be different!
Post Tue Dec 14, 2010 9:09 am
Looks just the job for a track car :D
Wouldnt like to try and fit a glovebox round that though :)
Phill172
Post Mon Jan 10, 2011 2:34 pm
Christmas relax over, so this is how it stands atm
Still waiting for the front coilovers to arrive, however put my 5x120 rota grids on, wanted more width but couldnt find any, so there 8.5 f and 9 rears, little bit of arch work was needed mainly because of the suspension, anyhow big spacers will be going on to give it more width look. Plus they have stupid gay big sidewalls!
Update on manifolds,
using x5 manifolds are a great help on the drivers side, not so much on the passenger, basically on the passenger side they fire straight into the starter motor, however the standerd e34 manifolds can be modified easily enough to loop down.
chu346
Post Mon Jan 10, 2011 3:30 pm
Nice build, might go M60 myself.
What are the other options other than using spacers to lower the subframe?
Phill172
Post Mon Jan 10, 2011 3:34 pm
We used the spacers to lower the whole lot, just to give a little more clearence round the steering coloum, and also to give more clearance in the box tunnel,
just makes it a cleaner job!
chu346
Post Mon Jan 10, 2011 3:53 pm
So it's not because it catches on the bonnet or anything like that then?
What ratio diff you going to use?
Phill172
Post Mon Jan 10, 2011 4:10 pm
no not at all, it does fit in without as far as im aware
im using a 3.38 diff, however would like a shorter diff if possible, but im going to play around with see how it is first then make a decsion an see what i can find
glenn
Post Mon Jan 10, 2011 7:13 pm
chu346 wrote:So it's not because it catches on the bonnet or anything like that then?
no, it should be clear of the crossmember and not hit the bonnet,
without spacers
Phill172
Post Tue Jan 11, 2011 9:44 am
willnz wrote:e32 manifold also works well on the passenger side, not much modification needed.
Thanks, I tried every manifold there was, but not an e32, interesting to try one on the next one, its annoying as everything else can be sorted on the conversion quite simply and in various ways however the manifolds are a pain and most of the v8 conversions you can find are mostly left hand drive!
Phill172
Post Mon Jan 17, 2011 8:51 am
Small update
really motoring on with it now!
glenn
Post Mon Jan 17, 2011 5:17 pm
good progress phill
Phill172
Post Mon Jan 17, 2011 5:28 pm
Thanks very much, ignore the top mount positioning for now, there just 'in' for the moment, until I pick up some adjustable mounts
Post Mon Jan 17, 2011 5:45 pm
what the rad off the donor car?
Phill172
Post Mon Jan 17, 2011 7:22 pm
Simon13 wrote:what the rad off the donor car?
e36 m3 evo, had one laying around
crossie
Post Tue Jan 18, 2011 12:43 pm
http://i164.photobucket.com/albums/u28/ ... 0857_n.jpg
What size oil cooler have you got fitted there?
Phill172
Post Tue Jan 18, 2011 1:19 pm
16 row cooler
Phill172
Post Wed Feb 02, 2011 8:42 pm
Fired the motor up first time today, started no problems!
Theres a video on p1
Post Wed Feb 02, 2011 11:06 pm
Nice one, very satisfying :cool:
sajad09
Post Wed Feb 02, 2011 11:53 pm
Very nice :D
Phill172
Post Thu Feb 10, 2011 8:39 am
So brought the car home last night, two days to spare before I drive up to Silverstone in it!
Its crazy fast, I know there will be quicker things out there but the cars weighs sub 1000kg - cant be fully accurate till later in the week - and the V8 is one of the best iv driven from a 540
A little snip
sajad09
Post Thu Feb 10, 2011 4:26 pm
well done mate glad you got it ready in time.. you make it look so easy!
Theo
Post Thu Feb 10, 2011 8:49 pm
Sweet 8)
Sub 1000kg touring? Does it have a cage?
Post Thu Feb 10, 2011 9:43 pm
That gets a wiggle on nicely 8)
Phill172
Post Fri Feb 11, 2011 9:57 am
Thanks guys, however yesterday pinged a driveshaft I think the cv was dodgey from the beginning, thats an easy fix.
However one problem is a pipe that needs to be changed, the jubilee is just rubbing enough on it when the engine rotates to slice it and cause a leak.
Easy fix although i need mini hands as its at the back of the block lower heater matrix!
Just good to find the teething problems!
Heyho only got to get to silverstone tonight with it! 8O There will be photos and videos over the weekend of it running
Regards to driving, in the dry 2nd gear itll light up and in the wet 3rd will spin with any throttle so its seriously fun, handling is amazing thanks to RPM topmounts and E36 M3 Evo suspension & brake set ups
Its running a 3.38 diff at the moment so itll top out around 140mph ish, the accerleration is relentless and brutal!
Theo - No cage just yet, however a full turrets/diff mount weld in cage is going to be fitted soon in the next few months
I cant again say how amazing the job Robin Welsh at Rawmotorsport has done with this car, on such a short time scale given the mess up by a company we were using for the flywheel.
Rawmotorsport are now going to be creating these conversions and can work on a very quick time scale!
