m20 323 m20 325i differences.....
mybmw6
Post Sun Sep 25, 2005 4:19 pm
Apart from the bore and injectors is there anything different about the m20 323 and m20 325 engines? Do they use a different ECU? I cant seem to find out any information about the 323. I have the bentley manual (think its bentley, its not in front of me) and it covers the 318i, 318is, 325i, 325is 325ix etc but makes no mention of the 323 at any stage? I wasn't sure if there was a reason for this... Any light on the subject would be great. :roll:
pemari
Post Sat Oct 01, 2005 1:18 am
I`m sorry if my english is bad but i`m from Finnland!
But here is some differenses between b23 and b25
-b23 use L-jetronic
-b25 use Motronic
-Ecu
-air flow meter
-engine harness
-cylinder head with camshaft and valves/valve springs
-intake- and exhaust manifold
-crankshaft
-connecting rods
-pistons
-cylinder block
-flywheel
-etc.
A1BMW325iSport
Post Sat Oct 01, 2005 1:57 am
L-jetronic - distributor fitted to block
Motronic - distributor on end of camshaft
mybmw6
Post Sun Oct 16, 2005 7:46 am
Thanks for that, I've found out what I needed to know. Much appreciated :)
