Hi. I don't no if anyone can help me i have an F reg E30 316 on carbs and i have changed the engine to a 325i M20 out of an 1986 E30 but the engine connector block that joins the engine lomb to the main harness does not match up. Is anyone able to help me shine a light on how to do this.
Many thanks
ENGINE CONVERSION (WIRING)
Do you mean different plugs, pins or wire colours?
The plugs should connect up as normal
FormerMember
Here you can find all you need for the wiring; http://shark.armchair.mb.ca/~dave/BMW/e30/
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
crossie
there a link like this for E36 wiring??Jonsku wrote:Here you can find all you need for the wiring; http://shark.armchair.mb.ca/~dave/BMW/e30/
FormerMember
crossie wrote:there a link like this for E36 wiring??Jonsku wrote:Here you can find all you need for the wiring; http://shark.armchair.mb.ca/~dave/BMW/e30/
Sure; http://www.gbnetwork.co.uk/bmw/downloadetm.html
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
crossie
Thanks for the links
