What are they?
and how easy is it to put an m5 engine into an E30?
Thinking more of the older 6 pot engines
M5 engine numbers
jmc330i
S38B36 and S38B38 I think. B36 is the 3.6, B38 is the 3.8.
Not easy or cheap to fit at all.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
- Homo Hair
This..jmc330i wrote:S38B36 and S38B38 I think. B36 is the 3.6, B38 is the 3.8.
FormerMember
S38 (6-cyl), S62 (8-cyl) and S85 (10-cyl) are the M5 engines. All of them have been swapped to E30's many times. S62 is the hardest, S38 the easiest. Every swap is very expensive.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
UweM3
S62 swap is not so difficult anymore. You just need to know th right peopleJonsku wrote:S38 (6-cyl), S62 (8-cyl) and S85 (10-cyl) are the M5 engines. All of them have been swapped to E30's many times. S62 is the hardest, S38 the easiest. Every swap is very expensive.
FormerMember
Yap, the electronics aren't the problem as Tino @ www.e30.de can do the flashing of ECU. But everything else is harder in V8 (mainly brake booster and exhaust manifolds), as with the others you can use original parts "bolt-on".UweM3 wrote:S62 swap is not so difficult anymore. You just need to know th right peopleJonsku wrote:S38 (6-cyl), S62 (8-cyl) and S85 (10-cyl) are the M5 engines. All of them have been swapped to E30's many times. S62 is the hardest, S38 the easiest. Every swap is very expensive.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
UweM3
Tino uses the same guy I use for ECU reprogramming.Jonsku wrote:Yap, the electronics aren't the problem as Tino @ www.e30.de can do the flashing of ECU. But everything else is harder in V8 (mainly brake booster and exhaust manifolds), as with the others you can use original parts "bolt-on".UweM3 wrote:S62 swap is not so difficult anymore. You just need to know th right peopleJonsku wrote:S38 (6-cyl), S62 (8-cyl) and S85 (10-cyl) are the M5 engines. All of them have been swapped to E30's many times. S62 is the hardest, S38 the easiest. Every swap is very expensive.
S62 in E30
S62 in E36
S54 in E30
S54 in E36
all not a problem
FormerMember
Okay, I thought it was Tino who was doing it. Well, anyways, have you researched the possibility to swap N62, N73 or S85 in E30 ? Or what about M54 or M57?
Lots of possibilites which are mostly limited by electronics..
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
UweM3
If you are serious I can ask the question. But think there is nothing available at the moment due to lack of demand.Jonsku wrote:Okay, I thought it was Tino who was doing it. Well, anyways, have you researched the possibility to swap N62, N73 or S85 in E30 ? Or what about M54 or M57?
FormerMember
Ok, no need to ask, I was just wondering..UweM3 wrote:If you are serious I can ask the question. But think there is nothing available at the moment due to lack of demand.
It's great that S62 and S54 have been made easy to swap!
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
