m20 into m40
FMH
which fuel pipes do i connect, am i right thinking the tanks in m40 cabs have 2 inlets or outlets?
jmc330i
Do you mean the fuel pipes that run up into the engine bay?
You should have 3 pipes that appear by the nearside chassis rail - 1 feed, 1 return and 1 breather. You only need to connect the feed and return, the breather (from the tank) just gets tucked into the nearside suspension turret to vent to air.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
An M20 will run quite happily with the 'wrong' fuel tank. No need to touch the back end at all.
jmc330i
Whats the wrong fuel tank?Brianmoooore wrote:An M20 will run quite happily with the 'wrong' fuel tank.
James
'91 325i Sport
'91 325i Sport
55 litre one, in the case of a 4 to 6 pot saloon conversion.
jmc330i
Ah, got it. My M40 to M20 was on my touring.
James
'91 325i Sport
'91 325i Sport
