325 turbo help ?
RETRODRIVE
Post Fri Apr 23, 2010 9:32 pm
thinking of doing a 325 turbo , can i run standard ecu and injctors , if i want to run around 400bhp .
using a t4 turbo ish .
thanks
march109
Post Fri Apr 23, 2010 10:00 pm
Why post it in the wrong section? That would be an M20 engine.
Standard injectors won't go to 400bhp or anywhere near, 220-230 IMO tops!
Standard ECU - think again.
ross2009
Post Sat Apr 24, 2010 11:19 pm
Your gonna need a standalone ecu and about 42lb injectors to run that sort of ponies
you can just bolt it on and expect it to be fine that sort of horse power needs a spot on tune other wise it will just go pop it's more than capable of running it but I suggest u do more research on the matter I'm more than half way through doing my own but I've got years of experiance with turbo motors
fowler
Boost Junkie
Post Sat May 01, 2010 10:38 pm
buy m y set-up it runs 440 ish aTM with more to come :D
EX A-Tech Workshop bitch !!!
gone but not forgotten
