Ti22 wrote:I think I may have thought of a problem. There is no way of mapping for boost that I can think of, so it's never going to as good as a system that can accommodate for that.
Eeek
I didn't read your first post properly. Not a viable option for a turbo'd engine IMO. I assumed you were looking to re-map a NA engine with mods (cams, exhaust, intake etc).
Might be made to work if you can map it to the signal from a MAF sensor (possibly off a Vauxhall/Opel or similar). Not a good idea with a AFM. Won't work with a MAP sensor since ECU's that use a MAP sensor also use an air temp sensor (along with RPM) to convert the MAP signal to a "representation" of air flow. A MAP sensor on its own does not work like an AFM or MAF and in no way gives a signal that represents the air flowing into the engine.
If you plan to keep your injectors and introduce only minimal boost then a rising rate FPR, as Gunni says, is an option, although I am not a fan of these (maybe I just struggle with them). Since you are talking about the capability to do a complete re-map I would prefer to increase the size of the injectors and run at a constant pressure (as specified for the injectors).
But honestly, if you plan to go the turbo route best consider a standalone ECU as the Motronic really wasn’t designed with FI in mind. Modern after-market ECU’s generally include extra inputs and outputs for controlling all sorts of useful things on a turbo engine, such as the wastegate, turbo timer (at switch-off), water injection (if ever required) etc.
