How much would it cost to get a turbo engine fitted in place of my current? I will have all the parts needed for the conversion (engine is already turbo'd), so basically need someone to fit it all in and set it up for me to drive away?
Rough costs?
TIA
Fitting a Turbo engine.... How much to fit?
wullie325i
- CAUTION - unreliable trader!
depends on the level of the conversion but i would say between 1k - 3k
wullie325i
what engine do you have in mind as fabrication will bump the costs up a good deal if theres alot to modify to get it in the e30 then the managment side correct diff prop ect.
Conversion's already been done, all parts have been fabricated etc etc
Just needs fitting into another E30 (my cabby) and management setting up again.
I know Ant does it on here but he's quite a distance from me.
Gunni
Well where are you?
I have been known to do those kinds of things for the right amount of money
About 10mins from you Gunni, got that rocker cover off you
fuzzy
if its all ready to be dropped in with mounts etc already made id do the donkey work myself then take it to someone to get wired and set up.
Gunni
I agree with Fuzzy.
Do the spannering yourself and then come see me.
You have a PM Gunni
