Making the S54 swap easier
glenn
- Engine Transplant Services
ian332isport
And if anyone does buy this ECU, admire the laser engraving on the top of the box, as I did it
Kos
interesting
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
glenn
wow!, your a dark horse ian.ian332isport wrote:And if anyone does buy this ECU, admire the laser engraving on the top of the box, as I did it
UweM3
I am complete opposite, don't care about the cosmetics. Does it work???
Morat
Wow, that shifts the goalposts a little bit! 340bhp N/A from a stock engine!
What sort of cash are we looking at for exhaust manifolds?
e301988325i
Am I correct in reading that the 3.0L S50 kills the 3.2L S54 under 4000rpm?
I said:
e30topless said:
lock the wife in there
jaistanley
Manifolds: I'd suggest you get a BTB (or equivalent) S50 manifold and have the primaries modified to accept the S50 flanges rather than the S50 ones (three bolts, instead of 4) as the S54 drops straighrt into an E36 on its original manifold.
A friend of mine has an E36M3 GT and wants to fit an S54. I just sent him the links.
Makes me want to ditch my S50, purely so I can rev to 8.5k instead of 7.5k!
I'd be really interested in seeing how the base maps were derived.. IE are they a dump of the BMW ones that are interpolated to the sites of the new ecu? These engines are notoriously hard to map correctly.
glenn
i know my car is lhd, but, the S54 manifolds cleared my crossmember/arb , cleared the bulkhead, and cleared the lollipops. and with them only having three bolts per flange, they can be fitted in minutes.jaistanley wrote:Manifolds: I'd suggest you get a BTB (or equivalent) S50 manifold and have the primaries modified to accept the S50 flanges rather than the S50 ones (three bolts, instead of 4) as the S54 drops straighrt into an E36 on its original manifold.
jaistanley
'minutes'... LOL
It'd be interesting to get some pictures if you have any glenn, to see how they'd foul the RHD steering column..
Jai
Jai
S54 manifolds are easy work compared to earlier stuff
winx
it would be very interesting to see how the costs stack up between the S50 and S54 swaps. Does anyone know how much you could get an s54 engine/gearbox + ancillaries for?
jaistanley
At the moment, they are relatively cheap! I imagine it's because they're not so good for swapping (electronics), because there are loads of newer cars around etc.
Theo
I know of a CSL engine for sale for £3k... that would be lively.
glenn
the thing is jai, every nut can be tightened with a socket and ratchet, unlike the s50 where, some have to be done with a spanner.jaistanley wrote:'minutes'... LOL
i didn't take many pics of the s54 swap i did jai, as there didn't seem that much interest, and now that car has long goneIt'd be interesting to get some pictures if you have any glenn, to see how they'd foul the RHD steering column..
i know for one at the moment, cheap.Does anyone know how much you could get an s54 engine/gearbox + ancillaries for?
'a friend of a friend' damaged his e46 m3, and broke the car himself.
he sold the engine and gearbox to his boss (garage owner).
neither of the two knew the engine/gearbox's value, so the 'boss' had the both for £500 !
the 'boss' hasn't done anything with it yet, as it's too complicated for him, and the 'seller' has started to realise what they are worth, and is thinking of having it back and re-selling it on.........and of course....i've showed an interest
winx
well if it was still going for £500 I would come and collect it tomorrow
Let me know if it is for sale as I'm very tempted...
e21Jason
Nice find
Does the s54 require a sump swap
Jason
Jason
glenn
hello jason,e21Jason wrote:Nice find
Jason
it's basicly the same items needed as the s50 swaps.
i used the e34 m50 sump / dipstick & tube / s50 3 litre oil pump
winx
well been searching for an engine and not been able to find one with the usual suspects yet (FAB etc) still on the lookout
Does anyone know if the ancillaries from the M54 will fit the S54? Might make the search a little easier...
Also need to find out if this ecu will run a csl engine as I believe the wiring looms and management are different due to the plenums...
Dave_M3
Friend of mine has his S54 in his RHD E30 drift car, just need to sort out the management now as he bought Link for it last year when he got the engine.
Will probably use the Typhoon myself for my own one.
I know somebody looking for an S54 and 6 speed manual for a 3L E36 M3 so would be interested in that engine if it was still going cheap or if anybody knows of any others about.
