SUSSPENTION Advise M30B35
simoniko
Post Thu Nov 19, 2009 11:12 am
Hello mates , i am recently installing a M30B35 in my e30 320i/1991 , what is the best suspention solution for the new engine , springs and shocks ?
I am thinking about H&R springs on 35mm, but the shocks i dont know ?
I have now H&R 60/40 mm on my car , do you think it will work with it , only to change the shocks?
gareth
Post Sat Nov 21, 2009 12:18 am
you may struggle with a 60mm drop at the front, it will be nearer 70mm with the M30 fitted.
uprated shocks are a must imo.
i'm running Leda coilovers with 500lb springs up front on mine as i had problems getting a set of well matched springs and shocks for a touring with a heavy nose.
toby
Post Sat Nov 21, 2009 11:35 am
Leda coilovers - I noticed you mentioned you had those Gareth - must have been costly. did you try the Alpina solution of E30 M3 (with air con) front springs?
(Assuming I got my facts right here.)
simoniko
Post Sun Nov 22, 2009 9:15 am
I am thinking of H&R springs and shocks 35/35 mm , or KW 40/40 mm! For a daily driver i dont need coilovers ! Somebody with M30 should advise how this was solved in his conversion!
ShakeyC
Post Sun Nov 22, 2009 3:15 pm
I thought Leda closed down years ago?
leeparkes
Post Sun Nov 22, 2009 4:54 pm
Ive got 60mm apex spring on my m30 powered turd and it is more like 70mm
ive got some 40mm springs to put on but ive been too lazy to bother :o:
coilovers are the answer but at a cost
gareth
Post Sun Nov 22, 2009 10:49 pm
toby wrote:Leda coilovers - I noticed you mentioned you had those Gareth - must have been costly. did you try the Alpina solution of E30 M3 (with air con) front springs?
i didn't try those no.
my legas were sourced second hand for about £450 with k-mac adjustable camber/castor top mounts
ShakeyC wrote:I thought Leda closed down years ago?
they did but they're alive again now. new management afaik
toby
Post Mon Nov 23, 2009 9:22 am
simoniko wrote:I am thinking of H&R springs and shocks 35/35 mm , or KW 40/40 mm! For a daily driver i dont need coilovers ! Somebody with M30 should advise how this was solved in his conversion!
Being a bit tart asking for advice in this way aren't you? I know that Gareth pursued a fair amount of research before choosing his suspension set up. I also mentioned how Alpina sprung their E30 M30 conversion and you sound sour! Perhaps you are foreign without a full command of the language but wind your neck in - the guillotine was invented in England you know.
simoniko
Post Mon Nov 23, 2009 7:13 pm
Dear All , please take my deepest appologies if i have offended somebody without meaning and by mistake !
I would be very happy if you could share your expirience with me for my suspention problem , my personal opinion is that coilovers are not needed for a daily car !
Thanks for your attention in advance
Yours Simeon
P.S.: Dear Toby , i am from Bulgaria -the bombing from aircraft was invented in Bulgaria , during the Balkan war ! winkeye
gareth
Post Mon Nov 23, 2009 11:26 pm
simoniko wrote:P.S.: Dear Toby , i am from Bulgaria -the bombing from aircraft was invented in Bulgaria , during the Balkan war ! winkeye
hahahaaa! that's brilliant! :D
no offence taken this end by the way. i personally sourced coilovers as that would be the easiest way of ensuring i getthe spring rate and ride height i needed without spending £££££ on many sets of springs to 'try out'
coilovers need not be expensive :wink:
http://cgi.ebay.co.uk/BMW-E30-Adjustabl ... 45ef631685
he also does DIY coilover kits too :D
toby
Post Tue Nov 24, 2009 10:22 am
simoniko wrote: P.S.: Dear Toby , i am from Bulgaria -the bombing from aircraft was invented in Bulgaria , during the Balkan war ! winkeye
Ha ha :D
charlE30
Post Tue Nov 24, 2009 5:08 pm
I've run both KW 60/40mm and Apex 60mm on my M30B35, both brought new with matched uprated shocks and neither sat any lower than when the M20 was in. I did poly bush the whole car and replace all ball joints at the same time so may have helped with keeping the car at the correct height by tightening it all up.
If you've got H&R 60/40 give it a try if you like the way the car drives, you may found it sits the same.
BMW F31 335d xdrive
simoniko
Post Tue Nov 24, 2009 9:13 pm
Ok , i will leave the 60/40 H&R and i will change the shocks , KONI or BILSTEIN you will say and what models ? i am thonking of B6 bilstein or yelow KONI , what do you think?
If i dont like how the car is standing i will change the front springs with 35 mm ones!
