Hi guys i'm in the middle of an M50 non-vanos conversion into what was a 1990 e30 316i. Both are manual and the M50 came from a 1991 e34 525i sport. I've been given a list of the functions of the wires for both the e30 and m50 loom to body plugs but on closer inspection the wires i have do not match with what i have been given in the list.
Heres the colours of the wires i have and the numbers they correspond to:
M50
1. BLUE/WHITE
2. BLUE/YELLOW
3. RED/WHITE
4. BLACK/BLUE
5. BLACK/WHITE/ YELLOW RINGS
6. PURPLE/WHITE
7. BLACK/PURPLE
8. GREY
9. GREEN/BLUE
10. BROWN/BLACK
11. BROWN
12. BROWN/PURPLE
13. GREEN/PURPLE
14. BROWN/RED
15. GREEN/BLACK
16. WHITE/YELLOW
17. WHITE/PURPLE
18. BLACK/YELLOW
19. WHITE/GREEN
20. BLACK
21. GREEN
22. GREEN/WHITE
23. BROWN/GREEN
24. WHITE/BLACK
25. BLUE
E30
1. BLUE
2. (EMPTY)
3. (EMPTY)
4. BROWN/PURPLE
5. BROWN/GREEN
6. GREEN/WHITE
7. GREEN
8. WHITE/BLACK
9. BLACK
10. (EMPTY)
11. WHITE/GREEN
12. BROWN
13. GREEN/PURPLE
14. BLACK/WHITE
15. BLACK/GREEN
16. WHITE/BLACK
17. (EMPTY)
18. BLACK/YELLOW
19. (EMPTY)
20. RED/YELLOW
Can anyone tell me what their functions are?
Many thanks
E30 316i M50 wiring loom HELP
A list I keep saved for occassions like thes
M50 1/ blue/white (dynamic oil level) E30 2/green/yellow
M50 2/ blue/yellw (static oil level) E30 10/blue
M50 /3 red/white (ABS) E30 20/ red/yellow
M50 4/ black/blue (aircon) E30 not used
M50 5/ black/grey (aircon) E30 not used
M50 6/ purple/grey (aircon) E30 not used
M50 7/ black/purple (drive away) E30 not used
M50 8/ grey (engine check light) E30 12/ grey
M50 9/ NC
M50 10/ NC
M50 11/ brown/yellow (water temp) E30 not used
M50 12/ brown/purple (water temp) E30 4/ brown/purple
M50 13/ green/purple(fuel pump) E30 13/ green/purple
M50 14/ black/white (speed) E30 14/ black/white
M50 15/ black/green ( unloader relays) E30 15/ black/green
M50 16/ white/yellow (Rx data) E30 not used
M50 17/ white purple (Tx data) E30 not used
M50 18/ black/yellow (starter) E30 18/ black/yellow
M50 19/ white/green (service reset) E30 11/ white/green
M50 20/ black (engine speed) E30 9/ black
M50 21/ green (ignition) E30 7 green
M50 22/ green/white E30 6/ green/white
M50 23/ brown/grey (oil pressure) E30 5/ brown/green
M50 24/ white/black (fuel rate) E30 8/ white/black
M50 25/ blue (ignition warning) E30 1/ blue
e:
M50 9/ NC
M50 10/ NC
e:
booomer
Hi thanks for the reply but pins 11 and 14 are still different colours between yours and mine, does this matter or is the function of the wire still the same? cheers
eko
- Old timer
Concentrate on pin number rather than colours
booomer
Ah thanks, thats what was worrying me. Which one was important, colour or number.
cheers
cheers
