2.8 or 3.5 ?????
Robbs
Post Wed Oct 28, 2009 4:58 pm
selling my mx5 soon and thinking of getting another e30 as the only car i've ever missed is my 327i, so i think im gonna buy a 318is and swap the engine, i've looked into the 3.5 before and seen the how to guide on here but im considering maybe chucking in a 2.8 on this one as they're newer engines and have similer torque (which is all i care about), so what i wish to know is.......
1) is there a similer how to guide, if not what parts would i need
2) is it more or less work than the 3.5 ?
3) is it much more expensive to do ? how much will all the bits i need roughly cost ????
4) so which would you do 2.8 or 3.5 ? and why ?
many thanks
..........THE ULTIMATE DRIFTING MACHINE..........
Post Wed Oct 28, 2009 5:06 pm
The Zone Wiki gives advice on 2.7/2.8 builds.
Robbs
Post Wed Oct 28, 2009 5:26 pm
i dont wanna build a 2.8 i want to swap for a m52 from an e36
stonesie
Post Mon Nov 02, 2009 4:34 pm
Have a look in the M50/52 section and there is a monster of a thread in there ''M50 developments''.
What i did was to read through it all, coppy/pasteing the bits i thought most relavent into works... then decided to keep it M20 8)
leeparkes
Post Mon Nov 02, 2009 5:40 pm
robbs wrote:i dont wanna build a 2.8 i want to swap for a m52 from an e36
Sounds like you've answered your own question.
//Rocky
Post Mon Nov 02, 2009 5:42 pm
Lol :)
gareth
Post Mon Nov 02, 2009 8:06 pm
robbs wrote:i've looked into the 3.5 before and seen the how to guide on here but im considering maybe chucking in a 2.8 on this one as they're newer engines and have similer torque (which is all i care about)
my standard M30B35 with just a 1mm skim off the head (10:1 compression) has 238lb.ft of torque, and 220bhp.
200lb.ft is reached at about 1800RPM :D
what's the torque like on a M52?
FormerMember
Post Tue Nov 03, 2009 9:22 am
robbs wrote:maybe chucking in a 2.8 on this one as they're newer engines and have similer torque
No, they don't have similar torque. M30 is all about low-rev Torque whereas M52 is more middle-rev torque. The M30 grunt down low is just something totally different than in M52. S50 has same kind of Power down low than M30, though.
x5x engines are straight bolt-on with E34 oilpan & -pump, all you have to do is to sort out the minor things. M52B28 costs 1-2 times more than M30.
I'd do M52B28 or M54B30 because M30 is done already :)
Seriously, M50B25 with some mods would be my choice because it is much cheaper and can be tuned to quite easily to 250hp / 300Nm with sensible money.
On the other hand, S50 would be the way to go, even though it's a bit more expensive it gives you so much more power that it's andgood option anyways.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Gunni
Post Tue Nov 03, 2009 11:21 am
I´d like to see one example of a 250hp M50B25 tuned for sensible money.
100hp/liter coming from 76hp/liter does NOT get gained with only sensible money.
Gunni
@ 2012 VEMS group buy !!
FormerMember
Post Tue Nov 03, 2009 9:28 pm
Gunni wrote:I´d like to see one example of a 250hp M50B25 tuned for sensible money.
2.8 crankshaft, Schrick intake cam, old intake cam to exhaust cam, megasquirt and some tuning => 265hp
Other example; cam swap and megasquirt => 240hp.
Still the total cost is less than in S50 swap, the M50 is really quite a good engine when driven by programmable ECU :)
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Post Tue Nov 03, 2009 9:49 pm
Jonsku wrote:On the other hand, S50 would be the way to go, even though it's a bit more expensive it gives you so much more power that it's andgood option anyways.
S50 is much more than a bit more expensive.. 10x more expensive at least
Post Tue Nov 03, 2009 10:34 pm
This means rebuilding the engine though which will soon soak up £1000, schrick cams are not sensible money either
FormerMember
Post Wed Nov 04, 2009 11:14 am
No way 10x more expensive.. Full M50B25 running gear with all the bits is around 1000€, whereas S50 is around 2,5-3,5k€. At least that's the situation here in Finland.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
FormerMember
Post Wed Nov 04, 2009 11:17 am
Well, we've different idea of "sensible" money, but only buying megasquirt and doing some tuning gets you to 230hp range. Adding S50 cam and 2.8 crankshaft (500€) gets you 30hp further. I wouldn't call that expensive..
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Post Wed Nov 04, 2009 1:31 pm
Here M50 swap costs about £500.. S50 costs about 6k..
Post Wed Nov 04, 2009 1:32 pm
Jonsku wrote:
DanThe wrote:
Jonsku wrote: 2.8 crankshaft, Schrick intake cam, old intake cam to exhaust cam, megasquirt and some tuning => 265hp
S50 cams don't work.. S52 cams are the ones used
FormerMember
Post Wed Nov 04, 2009 1:50 pm
Jhonno wrote:Here M50 swap costs about £500.. S50 costs about 6k..
Well, i checked autotrader and there're plenty of E36 M3's for sale for 3000£. Take the engine & gearbox and sell the rest, you'll end up quite even so the total cost is more like 500-1000£..
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
FormerMember
Post Wed Nov 04, 2009 1:51 pm
Jhonno wrote:S50 cams don't work.. S52 cams are the ones used
Yes i mixed it up with M52, but anyways my point was that you don't have to buy 1000€ / 2 cams when you can buy only one (used) cam and swap the old intake cam to exhaust cam..
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Post Wed Nov 04, 2009 2:13 pm
This is precisely what everyone thinks who is considering starting off with this swap, "it'll never cost that much" etc.
Everyone on here who has done this swap DIY has spent over £5k in the end
Post Wed Nov 04, 2009 3:21 pm
HAHAHAHA!
Considering the exhaust manifold is £1100 on it's own I think you are well off the mark
I have a mate who did exactly as you said, broke an E36 M3 for its engine, and it still cost him about 5k
Gunni
Post Wed Nov 04, 2009 3:23 pm
It´s like to see again ONE example of a standard M50 making 230hp from just tuning the fuel and ignition.
Your numbers are far fetched at best.
Gunni
UweM3
Post Wed Nov 04, 2009 4:08 pm
HAHAHAHA!
keep in mind, Finland = LHD!
FormerMember
Post Wed Nov 04, 2009 4:27 pm
I've done both M30 and M60 swaps all by myself to my cabrio so i know that the total cost is something else than just the engine.
Nevertheless, my point is that S50 does NOT cost 5 or 10 times more than M50. You have to do same updates to the car, were you swapping M50 or S50 in there so those costs can be forgotten now.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
FormerMember
Post Wed Nov 04, 2009 4:31 pm
HAHAHAHA!
How in hell you manage to spend 1100£ to a manifold? :D Of course you can spend 10 000£ for example to a valve cover made of gold but we're considering swaps made by enthusiasts, not swaps that are done only with money (and no skills by the owner) in a specialist shop? Right?
I made exhaust manifolds to my V8 cabrio with a help of my friend, all the parts cost less than 200€ and there're 2 more cylinders than in S50...
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
FormerMember
Post Wed Nov 04, 2009 4:39 pm
Gunni wrote:It´s like to see again ONE example of a standard M50 making 230hp from just tuning the fuel and ignition.
I'd like to show you but i'm afraid you can't see the dyno graphs before you log on to www.btcf.fi/forum
Here 184kW and Here 192kW.
M50 with 2.8 crankshaft & megasquirt, one doing 184kW with original injectors and other one 192kW with S50 injectors.
I've seen 230hp megasquirt powered M50B25, tried to search dynographs and the project-thread but didn't find it. I'll post it when i find it.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
FormerMember
Post Wed Nov 04, 2009 4:42 pm
Anyways, i don't want to argue does this and that engine make 240 or 250hp, or does this and that cost 3000€ or 4000€. Some basic facts should be dealt with, though.
-S50 swap is not 10x more expensive than M50 swap, but 1-2 times more expensive.
-M50 can be pushed to 260hp with stroking, camming and tuning for 1000€.
I think i've proven both of those points, feel free to prove me wrong :)
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Gunni
Post Wed Nov 04, 2009 6:54 pm
There is just no way you can gain 40hp from computer mods alone on a standard M50.
And the difference between a 193hp 2.8 and 259hp can not be a fuel and ignition tuning only.
That´s just the way it is. There have to be more details missing that gain 66hp on a 2.8.
Gunni
Post Wed Nov 04, 2009 7:31 pm
Jonsku wrote:
Jhonno wrote:
Jonsku wrote: Well, i checked autotrader and there're plenty of E36 M3's for sale for 3000£. Take the engine & gearbox and sell the rest, you'll end up quite even so the total cost is more like 500-1000£..
HAHAHAHA!
I am afraid you are just very wrong on the costs front.. I have done BOTH swaps, and helped with 2 more S50's.
A cobbled together manifold is fine for a relatively understressed V8, but the S50 is sensitive to the exhaust manifold, and it is easy to lose a lot of power.. The standard manifold is a work of art, and a lot of exhaust places wont even touch the work.. The only proven manifold out there is the btb, which time and again has made stock or above power, and is £1100. Therefore it is not a luxury, more a necessity. Then you still have the rest of the exhaust to make.. The two swaps are the same in as far as engine mounts and gearbox mounts and prop/diff, the rest is very different.
LHD is easier to retain the stock manifold and save plenty of money, but it is still much more expensive than an M50
baptie0
Post Wed Nov 04, 2009 7:46 pm
Jhonno wrote:
Jonsku wrote:
Jhonno wrote: HAHAHAHA!
Blah, blah, blah.
Jhonno, dont you ever stop whining about your btb exhaust manifold?
FormerMember
Post Wed Nov 04, 2009 9:18 pm
Gunni wrote:There is just no way you can gain 40hp from computer mods alone on a standard M50.
The 2.8 makes +200hp in real life as stock, just go try and dyno one. 193hp is the number they've released for tax-reasons.
Just last week friend of mine took 225hp out of standard 2.8, only modification was changing ECU to megasquirt. Before megasquirt it made ~205hp in the same dyno.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
FormerMember
Post Wed Nov 04, 2009 9:29 pm
Jhonno wrote:I am afraid you are just very wrong on the costs front.. I have done BOTH swaps, and helped with 2 more S50's.
So would it be possible that you actually list the costs which take you to 6000£ ? If for starters we state that you buy a running E36 M3 for 3000£, take the engine & gearbox out and sell the rest of it for 2000£ in parts. So you've 5000£ to spend, where do you manage to lose it all?
Yes i'm aware that S50 is making almost 100hp/l so the exhaust manifold has to be done properly. Still, i cannot see anyone spending 1500€ for one, because you can buy all the bits you need to do one for 100-200€ and fabricating one is not rocket science. The standard manifold is good, but they've had to do compromises with it anywas so it's not perfect. Even paying exhaust company to do one doesn't cost more than 500€ so still you're almost 1000€ off the target. Or is UK so much more expensive than Finland ? 8O
Well, is there anything remaining after those? Electrics is just cutting and connecting wires, brake booster clearance is thing which need to be taken care of, but i don't see anything else that needs to be done?
Yes, but fabricating the exhaust to M50 or S50 is the same, pipe diameter may be 0,5" different but that's all..
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Post Wed Nov 04, 2009 11:08 pm
baptie0 wrote:Blah, blah, blah.
Constructive post there, congratulations.. Unfortunately we're not all happy being bodge artists.. So what if I recommend a product which makes the most of a conversion, if it offends you that much then jog on and dont read it..
Post Wed Nov 04, 2009 11:21 pm
there won't of been much cost cutting in the design on the S50 manifold to get the first road car into production with over 100bhp p/l. As with all bmw exhausts the only problem is they're too quiet for most enthusiasts and heavy. They have the aftermarket licked generally
They're not stupid you know!
Post Wed Nov 04, 2009 11:33 pm
Ah ffs.. I just wrote a long reply Jonsku and it's not sent.. Cba to rewrite it now, I have work in the morning..
Post Wed Nov 04, 2009 11:35 pm
Sadly I dont remember all my costs, it's been a while.. The exhaust manifold and exhaust were the thick end of 2k though.. I dont have a break down of what my mate spent, but he bought a breaker, made some money back, but still reckoned he spent 4.5k odd..
Well, sadly I am no fabrication expert, but many companies were approached to sort the manifold, and only btb were willing to touch it.. The pipework is intricate equal length, i cant remember the details again but there is a lack of room to go up a size in pipe and make a decent manifold, and the standard dia pipe is difficult to work with or something the guy who did my exhaust was telling me.. Now he knows his onions, and does many manifolds for E30 M3's..
Oil cooler.. Coolant piping, most M50's just use cheap iS box/prop/diff, S50 is the ZF box requiring m3/328i prop and m3 diff. M50 can run a standard e30 325i exhaust or such like.. S50 requires a min twin 2" bore and ideally 2 boxes for noise, I paid for mine to be done, my mate made his own, and costs ended up being not far off each other.. I am happy I paid the extra for a lack of hassle.
It is stupid odds and sods that add up.. I spent more than most dropping mine in, after upgrading clutch/flywheel, arps etc..
Costs for the S50 swap have come down, I did mine 2-3yrs ago effectively.. If you dont have room to break an E36 an engine is still 1.2k-2k for something with warrenty, so that and a decent exhaust is 3-4k.. Yet you dont even have a box/prop etc yet
