Couple s50b30 Q's
Coldaccord
Post Mon Oct 26, 2009 12:27 am
what is the oil capacity? any sites online with engine torque specs? Who burns chips for them? Is there a registry here of s50 swaps? I checked the s50 forum, there was only 1 post
Post Mon Oct 26, 2009 1:19 pm
Oil capacity depend on oil cooler used.. Mine was about 6L inc cooler iirc, but I also have an extra wing welded onto my sump
There are chips on ebay.de. People like H&H do also
Don't think there is no..
Coldaccord
Post Tue Nov 24, 2009 2:15 am
i'm having trouble wiring up my temp gauge. anyone know of a wiring diagram online for the euro s50 harness?
Post Wed Nov 25, 2009 10:06 am
Temp gauge should work automatically if the c101 is done correctly and you have installed a brown M20 temp sender.. Do you have a B30 or B32?
Coldaccord
Post Tue Dec 22, 2009 5:18 pm
3.0. wire for temp gauge was in pin 12 on motor harness but 11 on body harness, so I amended that.
anyone have the last 7 of the vin for an s50b30 powered car? It's an unnecessary pain entering all the info on realoem trying to get part numbers
Post Tue Dec 22, 2009 6:01 pm
Oil capacity depends on which sump you use, for example, if you fit a 525i sump to an S50 dont go looking up the filling capacity for an E36 M3 winkeye
E34 sump with filter housing holds 6.5 ish litres, oil cooler will be even more
Pin 4 of the C101 is for the temp gauge, should be a Brown/Violet wire
RoadHazard
Post Tue Dec 22, 2009 7:44 pm
In RealOEM, you can select your car then bookmark that page.
