Help with diff's please
beamer_325i
Post Thu Oct 22, 2009 9:57 pm
Hi im doing a s50b30 swap with the 5 speed box into my 325i sport and need some help finding the right LSD.
i wood like 3.15 ,3.25 , 3.64 but dont now how much to pay or where to fined one.
what bmw's have the right diff's?
i still have the 3.91 out of the sport! can it be changed?
thanks for any help.
PS i live in shetland scotland, freight is very expensive
bulletproofbob
Post Thu Oct 22, 2009 10:28 pm
can i ask if anyone knows of an lsd that'll drop into my soon to be M50B28'd E36 320i... sorry ti hi-jack but its similar question, thought same people may know answer...
leeparkes
Post Thu Oct 22, 2009 11:58 pm
beamer_325i wrote:Hi im doing a s50b30 swap with the 5 speed box into my 325i sport and need some help finding the right LSD.
3.15/3.25 are E30 M3, 3.64 were on early tech-1 sports and some 325i's
Put a post in the wanted section
**BANNED**
Post Fri Oct 23, 2009 7:48 am
3.64 open diff should be around £50.
LSD's are in demand and fetch £250ish.
Another source of 3.15/3.25/3.09 diffs is E28,you will need to swap the output flanges and back plate for medium case E30 parts,though.
Youth is wasted on the young.
beamer_325i
Post Fri Oct 23, 2009 11:47 am
what about LSD's out of some E36 compacts! will they work? are all the E28 LSD's the same?
FormerMember
Post Fri Oct 23, 2009 2:45 pm
beamer_325i wrote:what about LSD's out of some E36 compacts! will they work? are all the E28 LSD's the same?
I think the compact units work as well.
E28 has medium (typ 188) and big (typ210) LSD's.
Good ratio for the diff would be quite near 3, for example 3.15 which is found on E30 M3.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
bulletproofbob
Post Fri Oct 23, 2009 3:41 pm
anyone for my e36 question then?? :(
beamer_325i
Post Fri Oct 23, 2009 8:50 pm
The compact diff will bolt straight in to the e30 sub frame.
Thanks, can you tell me what one will have the right ratio for the s50b30 conversion?
Coyote_ar
Post Sat Oct 24, 2009 4:02 am
i got my 3.15 LSD diff from an E36 323ti.
