Cheers will look into the 2.0 thing, feels a bit strong for a 2.0 though.
Major drama last night, picture a sodium lit car park in the middle of market drayton at about midnight, with me huddled against the freezing cold in my finest lady friendly clothes as I climb aboard the e30 and thumb the ignition. The odd pack of drunks stagger here and there as the mighty m50 fires up, I aim the bonnet over at the car park exit, and rumble forwards. The dark, empty roads of shropshire bekon.
Just imagine my disappointment, angst and inner turmoil then when I glance down before leaving the car park and notice that the oil pressure light has come back on again. fffuuuuuuuuuu.....
I've sold my runabout too
Having killed it again and ascertained that there was actualy some oil in the thing I tried it again, same result. But the light was weird and flickery, kind of 1/2 on and didn't respond to revs. The engine sounded perfect if a little rough cause of the MAF thing.
So I took an executive descisionm, tucked my balls in and went for it. I just drove it 20 odd miles home like that, no drama, no noises. Spend half the night lying awake stressing, going over in my head when I did the oil pickup, was the gasket on right, did I torque the bolts properly, could it be the sender, etc. etc. etc.
Anyway long story short it was the sender! I put the one off the M20 on and its fixed it. I spent the day giving the old girl some good lovin, cleaned up all the grounds, re grounded the ECU, put an extra ground on the engine, rotated the MAF so it was sitting up straight rather than canted over, swapped the heater hoses round so the heater actualy works. Swapped the rad for one that doesn't leak, replaced the missing front lip, washed it for the first time in months and some part of that lot has made the engine really wake up - the uneven-ness and un-willing ness has almost completely gone now. The idle's still a touch low but its much steadier now.
Having spent the day messing around with that lot I ended up not getting another maf. Still wanna try one though.
Daimlerman!! Still wanna sell me that MAF? Is it a non-vanos one? I tried a vanos maf that I picked up locally on friday night but sadly its only got 4 pins, mine's got 6 on it....
Cheers for the help so far all
