Which engine swap would make most sense for me, if any.
clydesdale
I want more power. I have 260,000 miles on my 87 325is. It still runs, handles and looks good. But, it doesn't have a lot of power. What is the best route to go? Engine swap? Rebuild the current motor? If rebuild, how do I get more power and still have a smooth driving car? Thanks.
Gunni
Check out r3vlimited and e30tech which are alot more US based forums.
Both have a giant knowledge base.
I´d say a M52B28 or a S50B30 (US) or a S52 would be a great upgrade path for you .
FormerMember
S52 is the US-version S50 ;)
M50 or M52 is the way to go when looking hp/$ and consumption ratios. Those are cheap and good engines and easily good to 220-250hp. When aiming around 300hp then S50 is the choice.
Anything upwards from there will start to cost quite a lot and can easily be achieved with superchargers or turbos.
But as mentioned earlier, check out r3vlimited and e30tech. There're lots of information (and also lots of BS)..
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Judging by where the original poster lives, I'd be putting in a LS1
As your in the US I'd imagine there are more ETA engines available. So M20 2.7?
