m52 question
RichIS
right thinking about a m52 conversion have managed to source a non ews m52 loom ready modified for an e30 would it be possible to use this on an engine that is equiped with ews to get rid of the ews ?
cheers
cheers
Injections nice....but I'd rather be blown ;)
- Homo Hair
there is no none ews m52
RichIS
whole cars being broken advertised on ebay as a non ews m52 unless the ews has been removed in the conversion ? :S
want to put an m52 to in my IS but the main thing putting me off is the wireing
If it doesnt have EWS its not M52 management, ive heard of the EWS being removed from the ECU via programming but the cost far outweighs the benefits IMO.
I cater for all 24v wiring solutions BTW
I can vouch for Dan's wiring as I've had 2 looms off him for 24v lumps now and each one has had the car running first turn of the key. I don't do wiring, so a plug & play solution was a must.
This one? http://cgi.ebay.co.uk/BMW-E30-325i-spor ... 1641wt_941
From the pictures I can tell you it has an E34 engine loom and a M50 2.0 or 2.5 cam cover fitted so could be anything.
What it isnt is M52
What it isnt is M52
- Homo Hair
Wiring is easy!RichIS wrote:whole cars being broken advertised on ebay as a non ews m52 unless the ews has been removed in the conversion ? :S
I think Rich was just interested in buying the loom, the ad says the engine is 'blown' low on compression
RichIS
yeh thats the one was just going to buy the loom,ecu, manifold, ect so all i would have to was get an engine and away i go but if its a mis match of parts it may not be the best way to go
looks like the search will have to contine for a good m52 with all the ews bits and peices which i belive i need the chiped key and barrel aswell as all the normal bits?
RichIS
right may have got a whole car to get bits from now just need to know where the EWS control unit, transmitter receiver module and antenna is located
RichIS
no i stayed well away from the cab after all the mismatching got a e36 to rape for parts so just wanna make sure i get every thing i need before it goes to the crusher
Or purplewillnz wrote:Ok, as above for the antenna etc. You will find the EWS module behind the glovebox in a stack of modules, it will have EWS on it and has a yellow plug from memory.
Bob_S
I've got a lovely m52b28 e30 ready sat here yours for £700
Ecu, ews all wired up nice just plug and play.
Bollocks to this 24v scrap!
Fook me that sounds like a bargain Mr S!
Im getting stuck into the 3 litre this week btw
Bob_S
good.. can we have it in for oulton? I should have a fanimold to use for then.. it's got 6 pipes.. and sexual
I want it ready for oulton, will be a good test run!
RichIS
typical as soon as i put a deposit down on every thing from a e36 this comes up 4 sale ..... any details on it ?Bob_S wrote:I've got a lovely m52b28 e30 ready sat here yours for £700
