M30 typical items that need a refresh before going into e30
jamie850
Hi, Picking up my 3.5L m30 soon and thinking about which items will need to be replaced?
I was thinking:
sump gasket
and plastic timing chain tensioner (but leaving on the same chain?)
conrod to crank bearing shells
while its out of the car.
I'm debating on taking the head off and cleaning up the ports with a die grinder and lapping in the valves. Has anyone done that and found it worthwhile?
thanks
I was thinking:
sump gasket
thanks
DRIFTBOY
Assuming the engine is in reasonable condition and not a rattly knocky old thing:jamie850 wrote:Hi, Picking up my 3.5L m30 soon and thinking about which items will need to be replaced?
Good idea, could save a load of hassle later.jamie850 wrote:sump gasket
So could crankshaft rear oil seal while you're at it.
The chain guides do wear and the plastic one gets brittle, I've not heard of them causing much trouble though.jamie850 wrote:and plastic timing chain tensioner (but leaving on the same chain?)
Might not be necessary but I would, just for peice of mind.jamie850 wrote:conrod to crank bearing shells
No!jamie850 wrote:I'm debating on taking the head off and cleaning up the ports with a die grinder and lapping in the valves. Has anyone done that and found it worthwhile?
Unless the head needs to come off or the top end is rattly (like a lot of them are) I'd leave it alone.
I'd also put a new water pump on, cheap and easier with the engine out.
Make sure the crank sensor lead is out of the way of the water pump pulley too, they can cut through them if incorrectly routed.
Also put threadlock on the large timing cover bolt that also holds the crank sensor bracket on, these are known to come loose and leak oil.
The oil spray bar for the camshaft is held on with two small banjo bolts.
Get new ones, and washers, as BMW modified them because it was quite common for these to come loose and starve the camshaft of oil.
Depends how far you want to take it really, but they are the first things I would do.
leeparkes
Crimp the spray bar in the middle aswell, here's a link/guideDRIFTBOY wrote:The oil spray bar for the camshaft is held on with two small banjo bolts.
http://www.cscoupe.org/tech/spray_bar_fix/70590.html
Also ive read somewhere about a return valve in the oil filter housing that can fail, not a major issue when they fail but it just takes that little longer to build oil pressure up, better return valves were fitted to later M30's, 1991 onwards i think.
inlet maifold might be an idea as that also would be awkward to swap with the engine in the car as it would fail the brake servo when trying to remove.
DRIFTBOY
Good point, inlet gaskets worth doing with engine out too.
I never knew that about the oil valve thing, interesting!
Driftben
Hmmm ya I didn't know about the valve too. Need a part number so I can get one
I have gone to town on my m30 mainly because I'm supercharging but also iv never rebuilt a engine before so it's a large learning curve.
It's wise to take the cam cover off to check the rocker arms as they are prone to breaking and stuffing the cam lobes.
Just a though
Just a though
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
mybmw6
Hahaha tell me about it! I was doing a simple swap, now there isn't one peice of the engine currently touching the other....I have gone to town on my m30 mainly because I'm supercharging but also iv never rebuilt a engine before so it's a large learning curve.
Driftben
Haha ya that's the main problem. I have a garage full of engine. I'm hoping I know where it all goes
6pot wilwoods front
4pot Porsche rear
gareth
have a close look at your clutch. expensive but a lot easier to do when out of the bay as the box doesn't clear the transmission tunnel....
looks like your clutch will be getting a hard life too.
inlet gaskets, definately! one of mine had split so i sealed the gap with silicone, only to find a few years later that it was 50% blocking one inlet port!
DRIFTBOY
It does if you chop the top bell housing bolt lug off the top of the gearbox!gareth wrote:have a close look at your clutch. expensive but a lot easier to do when out of the bay as the box doesn't clear the transmission tunnel....
It's still an arse of a job though, so I'd put a new one in now if the wallet can cope!
I'm using a standard LUK clutch which has covered about 20,000 miles now, and it's coping with forced induction admirably!gareth wrote:looks like your clutch will be getting a hard life too.
Driftben
have you got a standard flywheel driftboy?
how much BHP do you think your M30 is running? im looking for a clutch and flywheel combo with me supercharged M30.
dont want to go overkill with the clutch..
6pot wilwoods front
4pot Porsche rear
e21Jason
m30's use the large bmw clutch so stock is preety good, I am actually using an s14 uprated one on mine as it is smaller and lighter.
The rockers tend to brake at high revs so you should be okay with the SC if every thing else is stock. IE you do not want to rev more
Jason
Jason
DRIFTBOY
I'm using an E28 M30 solid flywheel (the E34 M30 is a dual mass, and about 50% heavier) and it should be running at around 300bhp at the moment, although I can't say for sure just yet.
Driftben
Crazy question but what does a dual mass flywheel look like? Looks like I could get away with either a standard m30 clutch or a s14 uprated one.
Jason is there and mods to fit a s14 clutch or is it a straight swap?
Thanks gents for the info.
Ben
Ben
6pot wilwoods front
4pot Porsche rear
e21Jason
s14 clutch is a smaller dia so you need the s14 flywheel to match.
Jason
Jason
Driftben
I see. I'll start having a look about. Might be easier to find a m30 setup? S14 stuff are like rocking horse poo.
6pot wilwoods front
4pot Porsche rear
e21Jason
Mitehave some e28 stuff knocking around give me a dew day to look down the lock upS14 stuff are like rocking horse poo.
Jason
Driftben
Ah lovely cheers Jason
6pot wilwoods front
4pot Porsche rear
jamie850
Thanks guys,
I'm looking to get the engine in first and running, then later when I've got more money put in a hot regrind cam, some motorbike throttle bodies on a homemade manifold and a megasquirt ecu.
I'll get the sump, inlet and crank gaskets all changed and give the rockers and bearing shells a look at too.
If I check the crank bearings for wear and they are ok, I assume that I can put them back in as long as I keep them in the same place? Does anyone know the standard thickness / tollerance the shells should be if I measure them?
where is the best place to get M30 parts such as gaskets and water pump?
Jamie
Jamie
