max power on standard internals
RussE30
what is the max power you can run on a 2.5 engine with standard internals when using a turbo?
Is the 2.5 engine in the e30 a m20?
billgatese30
Hi Russ
The engine is indeed an M20 but I'm afraid I'm not sure what the standard internals will take with a hairdryer feeding it.
Boyraceruk
I've heard 450bhp on, I believe, 9psi from Gunni, but the transmission wouldn't take it.
blingsta
- Boost Junkie
internals are all good upto the 350bhp mark..
Ant
- Retired Team Member
need more than 9psi to get 450HP
stock internals will eat 350, the stock clutch will take 280 ish max, stock tranny will survive 400+ but not for long !
Email FTW
jimmyspeed
what about a 320i as mines coming of the road, so i can get a bike
its has a v nice engine if slow -low mileage - what would that handle having a different head compression etc
thanks
thanks
Gunni
Get a 2.5 and use that. It´s going to make everything so much easier.
Stock internal M20B25´s will handle 500hp with the proper tuning and if you keep the torque "down", and I mean below 500lbs.
Stock pistons are the problem but I´ve not even heard about when they actually start to fail.
But I think people who want more then 500hp using m20´s go for rods and pistons
Boyraceruk
Don't forget uprated head bolts.
MarkT
What do you mean by proper tuning? Steel HG, Head studs, Rod bolts?Gunni wrote:Get a 2.5 and use that. It´s going to make everything so much easier.
E30 340i project in progress now 328 turbo
Breaking '97 728i Auto box, tubular manifolds and other morsels.
For sale E34 M50 sump, pick up and dip stick. PM for de
Gunni
no proper engine management tuning.
MarkT
Could you explain more please mate?
Gunni
You need somebody to tune the ignition advance and air fuel ratios.
Ideally it will be a fully adjustable standalone ecu.
MarkT
I kind of got that much mate. Wast there something specific that had to be done with the map i.e AFR's, advance etc.
Morat
Would turboing LPG be any different? With higher Octane rating and cooler charge temps (I think) can you boost it harder?
Gunni
Just have it done by a professional on a dyno.MarkT wrote:I kind of got that much mate. Wast there something specific that had to be done with the map i.e AFR's, advance etc.
Gunni
As long as you can tune the amount of LPG against manifold pressure and adjust ignition then you can tune it as long as the engine can take it or until you become knock limited.Morat wrote:Would turboing LPG be any different? With higher Octane rating and cooler charge temps (I think) can you boost it harder?
MarkT
Fair enough mate, so simple it has to make sence lol!Gunni wrote:Just have it done by a professional on a dyno.MarkT wrote:I kind of got that much mate. Wast there something specific that had to be done with the map i.e AFR's, advance etc.
