m20b25 turbo questions.
pinpin
Post Wed Jul 29, 2009 8:28 pm
Hi all, just wondering if i can pick your brains on a few questions i have on my up and coming conversion.
First off the car is an 87 325i se. Am i right in thinking this has the earlier higher comp engine?
I already have:
garret t3 with ar60 outlet
exhaust manifold
large fmic
external wastegate
Anyway i have just bought a complete later lump from a 1990 model to work on and develop whilst keeping the car on the road. Im hoping for around 300-350hp.
First of all is it worth stripping the engine down to skim the pistons to lower the compression, if so how much is the recommended maximum amount i should skim them by? or can i get away without touching the bottom end.
Where can i get uprated head bolts from?
What injectors are people using, i thought about 444cc skyline ones, Would these be up to the job? or are there other alternatives.
Im planning on running a megasquirt v3 on this setup where can i get one, and do they come with diagrams/instuctions etc. I have a spare engine loom so i assume it will make the fitting easier.
Any help is much appreciated.
cheers guys.
Ant
Retired Team Member
Retired Team Member
Post Thu Jul 30, 2009 10:46 am
late B25 6K1 engine is 8.8:1 CR, no need to go lower unless you're going to run 1.5 Bar ++
T3 is a little small , what trim sizes dude ?
Imjectors are the wrong type, you need high impedance units , 42 lbs/hr llime greens from a mustang are my current favorite choice
as for the MS- happy to assist there with supply/build/fit/map whatever :thumb:
FYI stock CR, MS and wasted spark, smallish T3B18 with 0.63AR hotside @ 7psi is 270 HP(crank) with no issues.
HTH :thumb:
e30_Turbo
Boost Junkie
Post Thu Jul 30, 2009 11:39 am
Welcome to boostville :)
I can help with the uprated head bolts if you need :)
