M50 bits
SUMPCRACKER
Post Sat Jul 04, 2009 2:45 pm
Ive read the sticky..
What i dont understand is, if the M50 block is the same as the M20, why cant the M20 sump be used?
I also see its possible to use M20 gearbox/fly/starter/prop with modified linkage and mounts, or have i misunderstood?
ian332isport
Post Sat Jul 04, 2009 4:32 pm
SUMPCRACKER wrote:if the M50 block is the same as the M20
They're different.
You have.
SUMPCRACKER
Post Sat Jul 04, 2009 10:43 pm
They're different.
You have.
It seems i havent, found more than one person has used box/prop ect on other forums.
Post Sat Jul 04, 2009 10:48 pm
you mean the bell housing stud pattern is the same?
Post Sat Jul 04, 2009 10:49 pm
I'm using an iS box with M20 flywheel and starter motor
Post Sun Jul 05, 2009 1:03 am
A variety of gearboxes, etc. can be used with an M50 engine in an E30, but the only sump that will do is the E34 24V one.
**BANNED**
Post Sun Jul 05, 2009 1:02 pm
Only simularity between M20 and M50 block is the bore spacing is the same.
M20 gearbox may well bolt on to M50 block,but how do you intend to swap gears with the 'stick hard against the tunnel hole?
Easy solution is to use the M40 gearbox(Getrang 240),with a 320 gearstick mount.
M20 fly' will fit,but you need Mr Angle Grinder to modify the lower bottom sump/block area.(hold the fly in place and you will see what is required)This simple mod eliminates the 'orrible,heavy,dual mass M50 fly.
Use the matching M20 starter and clutch,of course.
Using the above mix means that a stock E30 prop can be used,along with the full range of E30 diffs.
Youth is wasted on the young.
