mpg guage with m30 conversion.
raj1980
since the conversion my mpg gauge has not worked. does anyone know how i can get it working with the m30 conversion?
Pin 8 of the engine loom socket on your car has a white/black wire connected to it, which feeds fuel consumption information to the cluster from the engine ECU.
IIRC, the M30 loom has this wire at a different pin on the engine loom plug, so it needs to be moved.
I'm not 'into' M30s, so I don't have the details, but I'm sure someone will be along with an exact answer soon, or you should be able to find it with the "search" function.
raj1980
i tried the search function but i never find what im looking for.
thats a great start, it points me in a direction to reading up on. thanks.
Ziggy
Look in the sticky thread at the top of the engine swaps section
raj1980
cheers Ziggy,
is that the same for pre-facelift model?
Facelift wiring mods (these apply to those with a facelift shell) - the engine will run without doing them, but for everything to function correctly, the following are needed;
To get the 'economy swingometer thingy' working you need to swap pins in the M30 loom:
Pin 3 (black and white) and pin 8 (black and purple).
