mk2ned
Post
Mon Jun 01, 2009 8:57 pm
I need help on my 2.7 turbo build
WHAT HEAD GASGET DO I NEED
If any one can help me out please get intouch.
THANKS GUYS AND GIRLS...
ShakeyC
Post
Mon Jun 01, 2009 9:00 pm
standard bmw one is fine, without knowing your build spec thats best advice stick to OE.
mk2ned
Post
Mon Jun 01, 2009 9:06 pm
The spec is 2.7 bottem end
JR rods
535 head
6 branch turbo manifold
t3/t4 hybrid turbo
spa turbo external wast gate
and nissian skyline map
some one said that a e39 m5 head gasget is the one ??? but im not sure??
ShakeyC
Post
Mon Jun 01, 2009 9:28 pm
no keep with standard bmw head gasket for that engine im guessing is M20. What pistons did you use and if the block or head has been decked you should measure everything work out your volumes and compression ratio too. Your map will be inappropriate too.
GrindCulture
Post
Mon Jun 01, 2009 9:30 pm
E39 M5's have V8s, so that wont work. I'd also recommend a custom remap, else you might as well not bother at all.
Not in E30s any more
mk2ned
Post
Mon Jun 01, 2009 9:57 pm
thanks for the help mate
you say a custom remap but i realy dont want to piggy back ecu.
i have got Q PANG managemant so not using stock rubbish.
pistons are JE low comp and a 535 head with cam
How about a 535 head gasget????
stonesie
Post
Mon Jun 01, 2009 9:59 pm
Are you sure it's a 535 head? thats a M30 or BIG 6 engine, the M20 2.7 block is a Little 6 so it just will not fit, the big size differance is just one of many reasons why not... Have a good look through the engine swaps section
Have you had anything taken off the block top?
ShakeyC
Post
Mon Jun 01, 2009 10:06 pm
It sounds like those parts are totally mis-matched, no offence but you will most definately better off paying someone more experienced build and map it for you.
- **BANNED**
Post
Tue Jun 02, 2009 12:47 pm
Have you a photo of the '535' cylinder head sat on the '2.7' block,please,I am facinated....
Youth is wasted on the young.
Ziggy
Post
Tue Jun 02, 2009 12:55 pm
An M30B28 is 2788cc, but something tells me that isn't the answer here...
Moving to the Engine swaps / FI section anyway
fowler
- Boost Junkie
Post
Sat Jun 06, 2009 8:46 am
jesus this bloke is asking for ttrouble i think this is on a m30 2.8 as ziggy says as its all a load of gobbldy gook ATM
EX A-Tech Workshop bitch !!!
gone but not forgotten
