m40-m42 temp gauge problem
jon552
Post Tue May 19, 2009 9:03 pm
hi, i have just completed a 1.8 is convertion on my 316 but i am having a bit of a problem - the engine warms up fine but the temperature gauge will only go up to just over the blue any one come across the same problem with this convertion?
jon
robbo86
Post Sat May 23, 2009 3:45 pm
Yes I have done the exact same thing, however guage really struggles to lift its self above the blue, the highest it has gone has been the quarter mark.
If you find a solution let me know. My car needs to go in for an MOT soon so if I havent sorted it by then I will ask the mechanics to have a look for me!
**BANNED**
Post Sat May 23, 2009 3:47 pm
Have you both checked/replaced your thermostats?
Youth is wasted on the young.
robbo86
Post Sat May 23, 2009 3:59 pm
Errrr...... no? Where is the thermostat?
appletree
Post Sun May 24, 2009 8:39 am
Front of the engine under the housing were the top and bottom hose connect, you need to drain the coolent first and you will need a new thermostat and thermostat housing gasket to. Not a major job though probly less than£25 if you go to GSF:D
pac1982
Post Sun May 24, 2009 9:34 am
Yes i had this problem fitted a new thermostat and sorted it, really easy job, you can test if your old ones knackered by putting it in a bowl of boiling water if it works you will see it move if it dont move its shafted.
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
robbo86
Post Mon May 25, 2009 1:44 am
What damage can a knackered thermostat do?
