[img][img]http://img402.imageshack.us/img402/5931 ... 932507.jpg[/img]
[/img] does any one wot that big piece with a bolt, on the turbo is, isnt there normally a pipe to attach boost controller like on the actuator
turbo part ????
carlrst
no one???????????????????????
leeparkes
Sure its some sort of built in dump valve (could be wrong)
carlrst
yeah could be, its got a spring inside
leeparkes
I had a tomcat turbo years ago and it had the same sort of thing on the turbo,i was told it was a built in dump valve.
james3320
yeah that is a built in re ciculating dump valve as used on the rover t16 turbo, there should be a vacuum pipe go in where the bolt is, someone has probably used an atmospheric dumpvalve with it...
carlrst
cheers, were can i get the pipe, and how can i attach a bleed valve, theres only 1 attachment on the actuator and not on the turbo
leeparkes
If you mean bleed valve to give you more boost then it goes on the actuator.carlrst wrote:how can i attach a bleed valve, theres only 1 attachment on the actuator and not on the turbo
james3320
think the thread is 1/8th npt for that fitting, the bleed valve goes in line in the actuator pipe
