The heater matrix pipes are extremly close to the inlet manifold and wondered how you got round it. What pipes did you use? Also where did you put the power steering resivour. Know its your own choice but would like idea's. Still got the joy of the wiring yet, And need some info on wiring charts for the e34 1991 m50 in an 1989 318i.
Jay
You can see my power steering thingy at the front n/s,over the ABS pump(it's a touring!) A better location IMO would be between the strut and washer thingy(I cannot spell reseviour either!) mounted where the coil was.You then would just need to drop pipes down to the rack...Others use the E36 type mount and shove it at the bottom of the engine bay by the n/s engine mount.Bit hit and miss for filling,though.My heater pipes are reasonabley clear of the inlet manifold,not quite sure what is going on there
