Given that the front of the e30 is so flat you may even find that, at speed, the air traveling over the bonnet leads to there being lower pressure just below it at the head lamps. Obviously the air that goes smoothly from in front of the car over the bonnet is going to go faster than the air that hits the front and pushes out, so the smooth airflow will be at a lower pressure, this would suck the air at the headlights up; either completely nullifying or reducing the ram air effect. In the worst case the low pressure area could reduce the pressure at the intake below atmospheric. ;)
I thought it might be interesting to do some maths on it, I hope it's right:
Say you have an m40b18 so 0.45l per cylinder swept volume. in one revolution 2 cylinders will intake making 0.9l per revolution. Say you are looking at the top end @ 5000 rpm, that's 4500 litres per minute (0.075 m^3/s). Now say your headlight aperture is 15cm, thus cross sectional area of ~0.018 m^2. Assume it is 10 cm long (0.1m) so for the sake of argument the relevant inlet volume is 0.0018 M^3 thus for 0.075 m^3 to pass every s that volume must be passed 0.075/0.0018 = 42 times per second. It is 0.1m long therefore the intake air must be traveling at 42x0.1m^s or around about 10 mph. With air approaching at, say, 70 mph you would obviously get an increase in inlet pressure. Unfortunately even if the air isn't being actively sucked out of the way by aero effects it has much easier lower pressure paths to go to than the inlet tract so it would raise the inlet pressure a negligible amount. That is assuming that you get the full pressure of the air going towards the car at the inlet, which I assume would need a coefficient of drag = 1, which I have on good authority is a bad thing
