I'm guessing it has quite a bit of potential seeing as the E30 M3 engine is based on the M42 and also having seen the engine in the E36 touring car which puts out over 300bhp also based on the M42 engine.
Having said that i'm not after massive power but between 160-200bhp would be nice.
What would a few basic things do for me such as a full exhuast system and superchip?
And please no comments like "Just drop a 325 motor in"
I was reading something on wiki about using pistons and a crank from other BMW motors but not sure how true this is seeing as anyone can write stuff on wiki heres the quote from wiki......
"Further, the long-stroke forged crankshaft from the M47 motor coupled with an overbore of +2 mm will make for a 2.1 L Stroker M42. The 86 mm pistons from a European 3.0 L S50 will produce a high compression, stroker M42 when coupled with the M47 crank. The addition of a MAF conversion from an M50 engine and properly setup cams, valvetrain, and tuning will yield potent output from the M42. "
Any help at all would be great
