M50 Dash lights on and hunting after swap
anderson
Post Sun Mar 29, 2009 6:10 pm
Im nearing completion of my m5o swap, but ive got the park brake, brake fluid and charging light flashing when its first started up. It doesnt charge while the lights are on but after 30 seconds they go out and its charges. It also hunts when its warmed up, cold start is good, runs at about 1200rpm then drops and starts hunting. I know induction leak is popular but ive spent half a day with brake cleaner and cant get it to change tone.
Anyone had these problems during your swap?
Cheers.
SM AUTOS
Post Sun Mar 29, 2009 8:23 pm
There is a rubber boot under the inlet manifold, make sure thats on properly as it can get disturbed and that causes hunting.
The charging problem sounds a little strange, have you got everything connected properly, and is the engine earthed?
S M Autos, Unit 2, Lilyhurst Industrial Estate, Abbey Road, Sheriffhales, Shropshire TF11 8RL
Workshop 01952 677089
Mobile 07824 661286
Workshop & car storage space now available to rent, phone or pm for details.
anderson
Post Sun Mar 29, 2009 9:32 pm
ok cheers will try that ive googled same problem and found it could be alsorts - ICV, TPS, MAF, blue temp sensor, lambda sensor
werent to bothered about the lights a they do go out after a while and does charge.
Have you swpped an m50?
SM AUTOS
Post Mon Mar 30, 2009 8:32 am
It could be anything to be honest, did the engine run ok in the car it came out off? If so start with the basics..If you don't know it may be worth putting a fault code reader on it first and see if it throws any faults up.
I've got a m50'd 318i, been on the road a month now and done 600 miles, and so far so good, only let me down once when the fuel pump packed up. :(
Believe me it'll be worth it when you get it sorted, 24v E30 :D
Mobile 07824 661286
anderson
Post Thu Apr 02, 2009 10:05 pm
sorted it, found fuel pressure regulator pipe perished, and stil did not cure it, replaced idle control valve job done.
the lights are still on for around 30 seconds then they go out and it charges. :mad:
Mot on saturday looking forward to it bein back on the road!
