232 conversion Help!
leightaylor
Post Sat Mar 28, 2009 2:11 pm
Hello, im looking to buy an e30 316 with a 2.3 letre engine in, the bad bit is the head gasket has gone! its not too bad as me and my mechanic friend will be able to do the job ourselves.
The only problem is that the bloke doesnt have much knowlege on the engine conversion and doesnt know what one it is, he has said that it is from a 323 in the discription on the net but when i rang him he said it was from a 523 of a similar age (1989) apparently the only 323 was a E36 which was just a badged up 325 with a restricted ecu, which also apparently dosent fit in e30's or are very hard (correct me if im wrong here).
The person has just sent me the engine code i think i will post it up. i really need come clearing of the head, please. any help much apriciated
Pic he sent me below:
leeparkes
Post Sat Mar 28, 2009 2:34 pm
That engine code is for a 2.3,
personally id go for a 2.5 as they are a better engine all round
leightaylor
Post Sat Mar 28, 2009 2:37 pm
Is that an e30 engine code?
Yeah so would i personally but the conversion has already been done, does any one know of some good places for part qoutes?
Post Sat Mar 28, 2009 5:01 pm
Is this the black one that was on eBay, from Stoke?
leightaylor
Post Sat Mar 28, 2009 6:03 pm
yeah thats probs the one, you got the link?
Andy325i
Post Sat Mar 28, 2009 6:22 pm
leightaylor wrote:Hello, im looking to buy an e30 316 with a 2.3 letre engine in, the bad bit is the head gasket has gone! its not too bad as me and my mechanic friend will be able to do the job ourselves.
Easier to drop a B25 in there :)
leightaylor wrote: The only problem is that the bloke doesnt have much knowlege on the engine conversion and doesnt know what one it is, he has said that it is from a 323 in the discription on the net but when i rang him he said it was from a 523 of a similar age (1989) apparently the only 323 was a E36 which was just a badged up 325 with a restricted ecu, which also apparently dosent fit in e30's or are very hard (correct me if im wrong here).
E36 cars didn't come out until 1991, E34's were never made in 523's afaik. Early E30's were availible in 323's up until facelift (about 1988?)
What does it look like?
This is an E30 323 engine
and this is an M52 (from an E36 or E39 5 series):
Hth
Andy
Post Sat Mar 28, 2009 7:16 pm
Its defo an M20 Andy, headgasket gone was in the description, also needed other work, paintwork not much good, I was looking at it for a cheap track car but the seller turned down my offer, it made less at the end of the auction!
You should check out the wiring before committing to it, could be a few surprises in store!
leightaylor
Post Sun Mar 29, 2009 1:06 pm
The ebay listing ended then dan? yeah i have spoken to the bloke about the problems, i have seen some close up of the paintwork and it doesnt look that bad to be honist so all in all it could be a half decent car if fixed
Post Sun Mar 29, 2009 5:04 pm
This was over a month ago, where did you see it advertised?
leightaylor
Post Sun Mar 29, 2009 6:01 pm
oh right haha! its on pistonheads.
Post Sun Mar 29, 2009 6:46 pm
Cant find the ad...
leightaylor
Post Sun Mar 29, 2009 8:19 pm
Post Sun Mar 29, 2009 9:08 pm
Yep thats the one, same picture
Its just the same as any other E30 with a f*cked engine but the wiring is possibly abused also, new fusebox?
No point considering repairing the engine, you could buy a better one cheaper than the repair would cost
leeparkes
Post Sun Mar 29, 2009 9:34 pm
DanThe wrote:No point considering repairing the engine, you could buy a better one cheaper than the repair would cost
+1
leightaylor
Post Mon Mar 30, 2009 12:06 pm
Ok thanks people for the help, i will consider another E30 locally, i will be back!
