right then ladies & gents.
i've just been offerd a set of e36 325i coil packs & i was just wondering if it'd possible to convert an m20b25 from a dizzy to coil pack ignition?
or have i just got the wrong end of the stick & chasing shadow's?
any help & advise would be welcome.
just want to find out if it's possible & are there any improvments
it will make?
thanks for reading.
steve.
e36 325i coil packs
steve_k
ian332isport
You won't be able to convert an M20 to run coil on plug, but I guess you could mount the coil packs off the engine, and use regular HT leads to connect to the plugs. E36 coil packs really don't lend themselves to this very well, and a 6 way coil pack from a V6 of something else would be a better option.325msport wrote:right then ladies & gents.
it will make?
thanks for reading.
steve.
Unless you have other mods, it's not really going to give you any benefits, and you won't be a ble to use the standard ECU.
Ian.
steve_k
cheers for that.
looks like i won't be doing then lol
nevere mind i thought that might be the response.
thanks anyway.
thanks anyway.
