350i, want a v12 in my e30, how easy?
nicey
Post Wed Mar 18, 2009 7:16 pm
Really want to put a v12 in my tourer, Is it a case of buy a 750i and start swapping?, what gearbox?, engine mounts, rad etc.
Any info much appriecated :)
Post Wed Mar 18, 2009 7:20 pm
Good luck 8O
Ask dips346, he has got one :cool: :cool: :drool:
Post Wed Mar 18, 2009 8:34 pm
It's a lot of work dude, if you want to have a manual box then you're into silly money.
have a look at this thread
http://www.e30zone.net/modules.php?name ... 12+touring
Post Wed Mar 18, 2009 8:35 pm
Also, can you resize your avatar pic as it is shifting the page across too much
thanks
FormerMember
Post Wed Mar 18, 2009 8:36 pm
Easier than with V8.
Correct me if i'm wrong but if i've understood correctly, you can use stock motor mounts, hydraulic brake booster and stock exhaust manifolds so it's quite "plug'n'play" :)
Of course you'll have to fiddle with electronics a bit, driveshaft has to be shortened and probably you need to buy / fabricate radiator which goes under the E30 "locking panel" but no major problems.
If only V12 would be legal in E30 in Finland i'd done one already :)
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Post Wed Mar 18, 2009 8:54 pm
Why are they illegal? I would so love a V12 :drool:
FormerMember
Post Thu Mar 19, 2009 7:34 am
Displacement and power too big. Maximum power for E30 in Finland is 230hp and displacement 3,375 litres. Of course you can go around these barriers in one way or another but not with V12.. :?
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
