Post
Sat Feb 28, 2009 3:34 pm
It depends on what YOU want !
Personnaly in the same situation, i would love to have a sleeper 335i, so the exhaust would have to be quiet in town, and bit more agressive when pressing the right pedal, but not too much !
If going with Jetex, I would use :
- Standard E34 manifold and downpipes as they aren't too restrictive.
- Then make a flanged Y-pipe from the 2 downpipes, exit in single 2.5" pipe ( mount O2 sensor there if cat ) I believe you can use Jetex part#U906351R and reverse it.
- if using a Cat, put Jetex Part #UFILOK635MM flexi-joint to absorb vibes and heat.
- Install a Cat, 2.5" In/Out ( if you want one, I would use magnaflow as they are cheaper than Jetex ),
- For a more quiet ride, put a first silencer right after the cat ( smallest of the cylindrical 2.5" In & out Jetex part # U456300R).
- Then again single 2.5" pipe to an aft silencer with 2.5" single in, and straight 2x2" exits for the 325i look, Jetex part #U346351R.
- For the tailpipes I would just weld some 2' pipes and make a nice angle cut and polish, to look like a OEM replacement part.
For more sound, delete the first silencer !
All stainless of course !
I believe single pipe 2.5" is ideal for an M30, so that is what I would do if my M30 projects comes true !
Also try to get all components flanged up, then you will be able to replace any single part if failed, but you can weld the pipes and elbows.
All please tell me what you think of that setup ! thanks.
Cheers / Pierre
