how much can i sell m30 engine for??
blingsta
Boost Junkie
Post Fri Feb 06, 2009 12:17 pm
Just need to know roughly how much i can expect if i decide on selling my M30 3.5 engine and E28 dogleg box.. no leaks/rattles or smoke !!
Ziggy
Post Fri Feb 06, 2009 12:27 pm
Somewhere between £200 & £300 at a guess. Not seen what any have gone for recently though, & there might be more value in the box if anyone thinks they're particularly desirable! Have you got mounts & prop to sell too?
blingsta
Boost Junkie
Post Fri Feb 06, 2009 1:09 pm
oh yes mate, all thats needed for the whole conversion..
leeparkes
Post Fri Feb 06, 2009 1:50 pm
id say between £350-£450 if you have all thats needed to drop straight in an e30.
leeparkes
Post Fri Feb 06, 2009 2:25 pm
What year car did the engine come out of?
winx
Post Fri Feb 06, 2009 2:28 pm
Think I paid £600 for my conversion kit. Came with absolutely everything you need engine, box, mounts, rad, pipes, exhaust manifolds and anything else I can't remember!
blingsta
Boost Junkie
Post Fri Feb 06, 2009 4:05 pm
leeparkes wrote:What year car did the engine come out of?
not sure mate, but i know it had a full rebuild before it was dropped into the e30
.. i'd be happy with £700 for the full conversion set up, that would include, everything to just drop in and go
maxfield
Post Fri Feb 06, 2009 4:06 pm
Am I right in thinking the box is the Getrag 265 box that's used in E30 M3's ? :?
leeparkes
Post Fri Feb 06, 2009 4:09 pm
The reason i asked is because the earlier ones had less power!
Ziggy
Post Fri Feb 06, 2009 5:00 pm
£600's about right for everything. More than that would depend on how many miles are on the engine, how new the rad is (& what rad it is) etc.
Just a thought, the engine isn't out of an E28 too is it?
Post Fri Feb 06, 2009 5:07 pm
Maybe you can make a list of all the parts included?
leeparkes
Post Fri Feb 06, 2009 9:05 pm
Ziggy wrote:Just a thought, the engine isn't out of an E28 too is it?
Thats what i was thinking
Post Fri Feb 06, 2009 9:11 pm
Does that make a big difference?
leeparkes
Post Fri Feb 06, 2009 9:20 pm
later engines were better,
something to do with valve sizes and compression ratio.
Post Fri Feb 06, 2009 9:30 pm
leeparkes wrote:
ImysE30 wrote:
leeparkes wrote: Thats what i was thinking
I see, interesting to see which one it is then 8)
zaust
Zone day release
Post Sat Feb 07, 2009 8:43 am
He has the later engine on a e28 dog leg box. e34 rad which is as new with mount's. all pipe work was new, loom with ecu afm ect, engine mount's, manifold and down pipe's.
M30 Tech 1 Touring on gas.
Ziggy
Post Sat Feb 07, 2009 12:10 pm
Good good. The main issue with the earlier engine is that it's physically more difficult to get one to fit in an E30 engine bay.
Post Sat Feb 07, 2009 12:23 pm
somrthing to do with the rear waterpipe on the back of the head iirc, the new ones did away with this.
e30_singh
Post Sat Feb 07, 2009 1:28 pm
I have got pics of this will post up soon...
Post Sat Feb 07, 2009 1:53 pm
e30_singh wrote:I have got pics of this will post up soon...
:woohoo: :woohoo: :woohoo: :woohoo:
Finally, some more pics
oldroydsr4
Post Sat Feb 07, 2009 3:49 pm
if its an m535i dogleg box, they have been known to sell for £500 alone
e30_singh
Post Sat Feb 07, 2009 4:28 pm
This is a later M30 head
This is an earlier M30 head as found on E28's
Note the shape of the the ports.
Post Sat Feb 07, 2009 7:29 pm
Any pics of this engine OP?
blingsta
Boost Junkie
Post Sun Feb 08, 2009 2:14 am
oldroydsr4 wrote:if its an m535i dogleg box, they have been known to sell for £500 alone
winkeye winkeye winkeye
Hmmmm.. i better double check it then, im pretty sure it is !
Andy335Touring
Post Sun Feb 08, 2009 4:48 pm
Rav335uk wrote:somrthing to do with the rear waterpipe on the back of the head iirc, the new ones did away with this.
also the sump and oil pump need changing to the later ones
