85mm pistons?
87mtech27
Post Tue Feb 03, 2009 5:34 pm
is there any bmw model which came with 85mm pistons which could be used on a e30 m20
Post Tue Feb 03, 2009 6:00 pm
I think one of the M40 variants used 85mm
appletree
Post Tue Feb 03, 2009 9:42 pm
Think the M42 has 84mm pistons but dont quote me.
Think neil 320? tryed some as i bought a m42 head off him after he bought the engine to try the pistons :D
Post Tue Feb 03, 2009 9:44 pm
Didnt they use 85mm pistons to get 1.9 litres for the E36 things?
87mtech27
Post Tue Feb 03, 2009 11:01 pm
just to confirm, will a 85mm piston slip into the standard 325i block without any modification
e21Jason
Post Tue Feb 03, 2009 11:06 pm
No
You need to bore the block
Jason
maggspower
Turbo Farmer Tractor Driver
Post Tue Feb 03, 2009 11:47 pm
e21Jason wrote:No
Jason
Thats right, m20b25 is 84mm bore.
87mtech27
Post Wed Feb 04, 2009 3:16 am
maggspower wrote:
e21Jason wrote:No
Jason
thankz
does anyone know what mods alpina did to the 323i based c2 2.5 to get a displacement of 2556cc
reggid
Post Wed Feb 04, 2009 7:56 am
I belive they did 323i 76.8mm crank, 84mm bore
E30 325is with M20B31
odbod
Post Wed Feb 04, 2009 9:55 am
The 85mm pistons are indeed from the 1.9 M44 engine. Used in late (96/97 onwards) E36 318is 318ti compact and Z3 1.9
87mtech27
Post Wed Feb 04, 2009 10:19 am
sorry sound a bit silly asking this but what is the size of a (m20) 325i crank and a 325e crank
87mtech27
Post Wed Feb 04, 2009 10:29 am
also will the standard gasket set work with a 85mm bore
maggspower
Post Wed Feb 04, 2009 10:43 am
These are not silly questions, silly would be buying all the parts then finding they dont fit :D
The throw of the 325i crank is 75mm, where as the Eta crank is 81mm.
Not sure about the HG, you would have to offer it up to the block to see how mich you have to play with. Some people on here have had HG made by the likes of Ferriday engineering, but that will cost a few £££
Post Wed Feb 04, 2009 10:52 am
Use the search, 90% of what you have asked has been covered before, im sure google would answer most
87mtech27
Post Wed Feb 04, 2009 10:58 am
DanThe wrote:Use the search, 90% of what you have asked has been covered before, im sure google would answer most
i cant seem to find much on 85mm bore m20s or the head gasket.
goosiegander
Zonegoose
Post Wed Feb 04, 2009 8:30 pm
Are there not special oversize pistons for the b25? I thought looking at the bently manual there were 3 different diameter pistons available... :?
87mtech27
Post Thu Feb 05, 2009 2:27 am
goosiegander wrote:Are there not special oversize pistons for the b25? I thought looking at the bently manual there were 3 different diameter pistons available... :?
i thought your could go overbore aswell (upto 86mm iirc)
reggid
Post Thu Feb 05, 2009 8:27 am
i use 86mm pistons on stock headgasket though pistons have a chamfer
kimbo
Post Tue Feb 10, 2009 1:13 pm
85mm is the 2nd overbore from standard and would therefore be available from more or less anywhere. Guess std replacement head gasket would work.
Dont forget that pistons from M44 etc will have four valve pockets and will thus probably foul with the 2 valve head.
Kim
Post Tue Feb 10, 2009 5:44 pm
only standard oversize for rebuilds when the bores are shagged
Alpina have kept their formula a good secret no one has stripped one of these engines down to see exactly whats been done
goosiegander
Zonegoose
Post Tue Feb 10, 2009 7:17 pm
Ever in zone history? Shocking... 8O
