motronic vs. l-jetronic
87mtech27
Post Tue Feb 03, 2009 5:33 pm
which is better of the two, also will all of the wiring loom have to be changed to convert l-jet to motronic?
Post Tue Feb 03, 2009 6:29 pm
l-jet is to cars like an abacus is to computing.
Motronic, on the other hand, is a PC at least. A few years old one, but essentially the same as the latest models, although somewhat slower and less sophisticated.
Changing will need a loom change, mainly because the ECU plug has many more pins, and a fresh oil pressure switch, because the plug is different.
87mtech27
Post Tue Feb 03, 2009 6:36 pm
thanks Brian
will anything else have to be changed aswell?
87mtech27
Post Tue Feb 03, 2009 11:03 pm
by the way are all 325i's motronic,
from what i know the later 325i's had a 1.3 motronic ecu.
is this right or was that just for the south african market
AlpineAde
Post Wed Feb 04, 2009 9:53 am
Mine's an Aus delivered car and has 1.3, if that's any help.
87mtech27
Post Wed Feb 04, 2009 10:20 am
AlpineAde wrote:Mine's an Aus delivered car and has 1.3, if that's any help.
what year was it made
Coyote_ar
Post Wed Feb 04, 2009 11:17 am
afaik, all 325i are motronic. all 325e are motronic. all 323i are ljet. pre 87 320i are ljet, post 87 are motronic.
cant tell which version for motronic though.
Post Wed Feb 04, 2009 11:22 am
Motronic 1.3 came with the 1988-on models of 320i and 325i. Prior to this, early 325i's used Motronic 1.1 or similar, with pre-1988 320i and 323i models having analogue L-Jetronic.
http://www.e30zone.net/e30zonewiki/index.php/Motronic
87mtech27
Post Wed Feb 04, 2009 11:48 am
Speedtouch wrote:Motronic 1.3 came with the 1988-on models of 320i and 325i. Prior to this, early 325i's used Motronic 1.1 or similar, with pre-1988 320i and 323i models having analogue L-Jetronic.
thankz
AlpineAde
Post Thu Feb 05, 2009 7:22 am
1989
