M30 with Shrick 284/280/110 cam - valve clearances?
winx
Post Fri Jan 23, 2009 8:39 pm
Got the above in and running in my e30 touring now and want to check the valve clearances.
As stock I believe the m30 should be .30mm. On the shrick spec sheet it mentions .25 on inlet and exhaust. Does anyone have any reasons not to use the Shrick value?
Post Fri Jan 23, 2009 9:41 pm
No, do as Schrick say..
winx
Post Sat Jan 24, 2009 1:00 pm
cheers fella, will get them done tomorrow and see if it runs better!
diogogaspar
Post Sat Jan 31, 2009 6:03 pm
and share some input on the high revs, since the 3.5 is a stroker not a revver I'm wondering how will it behave with those cams,
Cheers mate
e30_singh
Post Sat Jan 31, 2009 6:22 pm
I have read somewhere that the M30 3.0 cam is a nice upgrade on the 3.5.... but also rare as rocking horse shit.
I might get a Schrick cam as well, read good reviews about them on american M30 sites. Where did you get yours from, and how much was it; thats if you don't mind of course.
Gunni
Post Sat Jan 31, 2009 11:59 pm
the E32/E34 B35 cam is the best original cam of them all, only shrick makes a better one.
Gunni
@ 2012 VEMS group buy !!
winx
Post Sun Feb 01, 2009 3:15 pm
not driven a standard engine so can't tell you the differences, Theo has done so you could maybe ask him.
It is still a lazy engine but does rev ok to 6k...
reggid
Post Mon Feb 02, 2009 8:19 am
Some M30 Cam data that you guys might be interested in.
E30 325is with M20B31
turkey
Post Mon Feb 02, 2009 11:38 am
I've got the schrick cam in my M30 but all it seems to do is move the torque higher up the rev range and bit less low end grunt which you do notice over the standard cam, personally i prefer the std cam as it use to feel like more torque accross the range instead of a burst of it higher up...
e30_singh
Post Mon Feb 02, 2009 11:50 am
turkey wrote:I've got the schrick cam in my M30 but all it seems to do is move the torque higher up the rev range and bit less low end grunt which you do notice over the standard cam, personally i prefer the std cam as it use to feel like more torque accross the range instead of a burst of it higher up...
Thats enough for me, not to get one! I like the M30's smooth power delivery, I do not want to compensate low end grunt.
reggid
Post Mon Feb 02, 2009 1:01 pm
are you running stock CR?
turkey
Post Tue Feb 03, 2009 3:05 pm
CR? as far as know everything is standard apart from the schrick cam and a speedtouch chip, just rebuilt top end. Not sure how much more power can come out of the engine without forced induction really, not unless spending silly money on throttle bodies and a trick mani anyway...
winx
Post Tue Feb 03, 2009 3:35 pm
excellent info guys, hopefully of use to people in the future as well :)
reggid
Post Wed Feb 04, 2009 2:03 am
turkey wrote:CR? as far as know everything is standard apart from the schrick cam and a speedtouch chip, just rebuilt top end. Not sure how much more power can come out of the engine without forced induction really, not unless spending silly money on throttle bodies and a trick mani anyway...
Ideally you want to up the CR with a cam like that as it helps with the lowend some. A hotter cam will tend to lose "dynamic compression' during low rpm running making it feel flat.
turkey
Post Wed Feb 04, 2009 7:19 pm
That makes sence, just wish i knew that when i bought the engine, will defo be keeping that in mind if i decide on a rebuild, cheers reggid.
Jon_Bmw
Dangerous when thinking
Post Wed Feb 04, 2009 8:49 pm
What is the standard m30b35 compression ratio. For the mi16, above 10:1 is required to have any noticeable improvement witha similar spec cam*
*As in a mildish cam as per the shrick one above.
DRIFTBOY
Post Wed Feb 04, 2009 9:01 pm
I believe it is 8.8:1 as standard.
Leaves room for a bit of booost! winkeye
Andy335Touring
Post Thu Feb 05, 2009 4:39 pm
DRIFTBOY wrote:I believe it is 8.8:1 as standard.
Close ! :) M30b35 9.0:1
If you want lower then try a 745 bottom end, 8.0:1 and has piston oil squirters for less det' and better durability.
With this cam i didn't lose hardly any torque, the small loss was from tickover to about 1.5k so no biggie really.
IIRC when i first put it in along with some head work and a chip i had 180lbft at 1.5k.
Towards the end, my 335 was using an Alpina B10 bottom end which bumped it up to roughly 10.5:1. It was a PITA to redo the squish areas in the heads combustion chambers though !
