Anyone running itb's on m30 ?
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
oakey
Toby una used M5 tb's on his m30 turbo. Probably your best option?
zaust
- Zone day release
e30_Turbo
- Boost Junkie
Andy335Touring
I thought they were too big but when i mentioned it to Dave Walker he thought they were OK because only 2 cylinders suck at one time.
If you do go ahead and get a set then chop the mounting lugs/flanges off the ITB's and an old m30 inlet, then weld the M30 lugs/flanges onto the ITB's, simpler than an adapter plate and trying to match up the differing port shapes.
Like Mark said the 'stat housing will need modding and it'd pay you to get a smaller servo and move it accross like the S50 boys do, this will mean you will have to mod the plenum less.
You would need to go AFM less to get the best out of them and a cam would help too.
zaust
- Zone day release
Gunni
intake valve is to small unless you where going to use 40mm bodies or something like that.
e21Jason
I had a set now on an other e21, adaptors are quire simple to make from some 10mm alloy plate. But if you want to use a set of Jenvey throttles I have a weber manifold
Jason
Jason
zaust
- Zone day release
Gunni
Even though, the original manifold is probably not limited at the moment.
so just going to ITB´s doesn´t have to make more power.
I´d put in a cam before doing ITB´s.
Then I´d have the head ported to the limit of the intake manifold and exhaust.
All before putting itb´s on.
The only thing they really do is you gain in throttle response and the acoustic profile of the intake system changes,
that may be good and can be detrimental as well.
Bolt on tuning whatever you find isn´t proper tuning, if you get my drift.
zaust
- Zone day release
diogogaspar
interesting this thread, what about simply sourcing a set of ITB's from a M88 engine and bolt on to it? remapp the engine and pronto.
will that be enough?
They share the same engine block although the M88 it's a 24v head or better yet, source a whole M88 head from an early 3.6 and bolt on a M30B35 using the complete hardware, cams, ITB's, ECU, etc, wouldn't that do the trick?
Andy335Touring
None of that will work, or if you could get it to work it's way way romoved from a bolt on job.
Only adapting the TB's is practical but still a lot of work.
diogogaspar wrote:interesting this thread, what about simply sourcing a set of ITB's from a M88 engine and bolt on to it? remapp the engine and pronto.
diogogaspar
yup you'll have to spend at least a day on a rolling road to make a proper fine tuning for the ITBs I was just taking thing forward a little bit more, since this isn't your common chip it, open air filter it, mild cam type of thingy
Andy335Touring
I always wanted to make a 3.8 M30 but it's to much cost for the M5 crank and the rest of the parts.
zaust
- Zone day release
If either of you are feelling flush....zaust wrote:Would be more cost effective to just source a complete 3.8 or 3.6 imo.Andy335Touring wrote:I always wanted to make a 3.8 M30 but it's to much cost for the M5 crank and the rest of the parts.
http://www.e30zone.net/modules.php?name ... c&t=121944
zaust
- Zone day release
Andy335Touring
zaust wrote:I wish I could. Doing the head on this m30 is killing me as it is. Ordered the thicker gasket from the dealers but it won't be in till next week, so still off the road..
(i'm rubbing a lamp but F A is happining)
Have you had it skimmed ?
You can also get the thicker gasket from ECP, probobly too late now though ?
zaust
- Zone day release
Jon_Bmw
- Dangerous when thinking
You need to be fairly flush to fit ITB's on any car if you are buying them rather than making them. Even on a 4 cylinder car you are in the thick end of a £grand +. Thats before you consider any management to control it.
Then you'd want a really really spiky cam, and solid lifters, more expense.
Seems an awful lot for a £150 engine that only has one inlet valve per cylinder. One of the 3.6 or 3.8 options suddenly seems to be a lot better decision as they come with multiple valves, ITB's and probably, although I am not sure, a spiky pair of cams compared to an m30.
Turbo it, or fit a different engine.
zaust
- Zone day release
It was more a thought than anything, But it is doable on a budget it's just seeing if it's viable. And at the mo it look's more like bbtb and a healthy remap would not give much less bt the tb's and msd would leave me more scope in the future.Jon_Bmw wrote:You need to be fairly flush to fit ITB's on any car if you are buying them rather than making them. Even on a 4 cylinder car you are in the thick end of a £grand +. Thats before you consider any management to control it.Then you'd want a really really spiky cam, and solid lifters, more expense.
