Fitting E36 318 is engine into E30 325i chassis
GJP
Post Wed Dec 10, 2008 6:22 pm
I'm in the midle of trying to fit an E36 318 is engine into an E30 325 chassis. I've already changed the complete sump assembly and am getting some trouble with the engine mountings as the sump is fouling the steering rack.
Any info about this topic would be gratfully received. Thanks.
appletree
Post Wed Dec 10, 2008 6:56 pm
Which mount are you using and which rubber mounts are you using?
Think the e30 rubber mounts are offset were as the e36 ones ar stright :D
