E36 radiator into an e30
Trise30rally
Post Thu Dec 04, 2008 10:11 am
I have heard this is possible using oe mounts, what exactly do i need to use?
Is this the right rad to use?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... otohosting
Jon_Bmw
Dangerous when thinking
Post Thu Dec 04, 2008 12:53 pm
That is the same rad that is used in a 318is. I have just fitted an e36 radiator into my iS.
Obviously its got the intergrated head tank as well. I had to remove a small plastic cowling that runs along the bottom of the rad(about the same width ans size as the metal bit-440mmx40mm) but i suspect a brand new rad might not even come with this?
I presume this is for your XE engined beast? If so, where abouts are the inlet and exit areas. Custom pipework is going to be needed I think. The above rad has top and bottom hose obviously and a smaller diater pipe(1") at the bottom of the intergrated header tank.
HTH a bit, measurements are approx.
Jon
