"Here we go" more m42 info needed
Baz666
Post Mon Nov 10, 2008 3:35 pm
lookin to start my engine swap this week and i`m a bit puzzled on were to start with the m40 rip out.
can any one start me off or is there a step by step thread on here some were, not good with engines but going to have ago.
as its the cheaper way
GrindCulture
Post Mon Nov 10, 2008 5:08 pm
Depressurise fuel system (by removing the fuel pump fuse and running the car til it stalls) battery out, radiator out, unplug the loom from the C101 plug, battery teminal and ecu, AFM off, earth straps, fuel lines, alternator, p/s pump, exhaust. If you're swapping the gearbox out too, propshaft and remove anything else holding the gearstick in the car, disconnect the gear linkage, gearbox mounts, engine mounts and you're out! I think that's it... :?
Not in E30s any more :(
Baz666
Post Tue Nov 11, 2008 1:52 am
GrindCulture wrote:Depressurise fuel system (by removing the fuel pump fuse and running the car til it stalls) battery out, radiator out, unplug the loom from the C101 plug, battery teminal and ecu, AFM off, earth straps, fuel lines, alternator, p/s pump, exhaust. If you're swapping the gearbox out too, propshaft and remove anything else holding the gearstick in the car, disconnect the gear linkage, gearbox mounts, engine mounts and you're out! I think that's it... :?
it s now 1.45 am thanks for your info done most of that, the gearbox is staying in going to be useing it with the m42 engine.
question: will i need the car of the front wheels if the gearbox is not coming out.
Post Wed Nov 12, 2008 4:59 pm
start with draining coolant, removing hoses and unpluging electrics prehaps ???
im sure thats where i started when i removed my m10 318i engine :mad:
Baz666
Post Wed Nov 12, 2008 5:04 pm
thanks alex, now off to work to rip out that all boring m40 and tomorrow i`ll be picking up an H plate 318iS to then rip that out, to put into my cabby :roll:
Post Wed Nov 12, 2008 5:06 pm
Baz666 wrote:thanks alex, now off to work to rip out that all boring m40 and tomorrow i`ll be picking up an H plate 318iS to then rip that out, to put into my cabby :roll:
i hope your using a knackerd IS winkeye :wink:
Post Wed Nov 12, 2008 9:10 pm
Should have done the m30 mate for the cab winkeye , better power and defo for a smile on the face.
But good luck with the swap anyway :cool:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Nov 13, 2008 12:24 am
r u doing the conv in the container u got it sotre in at the moment??
Baz666
Post Thu Nov 13, 2008 1:00 pm
yeah, no tax no mot been sitting for just less then 8 months, fresh battery and petrol she started on the button. she has done 112,000 on the clock with history she really is all there.
Baz666
Post Thu Nov 13, 2008 1:06 pm
cliffybabe wrote:r u doing the conv in the container u got it store in at the moment??
yeah cliff, whys that then fella, it`s stored at work in box with shed loads of Myst packs and the best of all i get to work on it all night with free electric.
anisotropy
Post Thu Nov 13, 2008 1:24 pm
Shouldn't you use the IS gearbox? its a sportier one on most models I think
Baz666
Post Thu Nov 13, 2008 1:56 pm
if someone can confirm this as i`v been told on a number of time theres really no difference.
DHFiS
Post Thu Nov 13, 2008 2:09 pm
iS gear box ratios. I think this is same as on the 318.
1st 3.72
2nd 2.02
3rd 1.32
4th 1.00
5th 0.81
Diff 4.10
Post Thu Nov 13, 2008 3:28 pm
does it have an is splitter, will you be selling it??
also has it got rear headrests???
presuming you are breaking the car ??
Baz666
Post Thu Nov 13, 2008 3:47 pm
Alex wrote:
Baz666 wrote:
Alex wrote: i hope your using a knackerd IS winkeye :wink:
sorry alex the iS spoiler is already sold to my buddy and this dont have rear headrests, but had a phone call to off another 318iS I might be getting to brake also, so i`ll let you know soon as.
Post Thu Nov 13, 2008 3:55 pm
:cool: thanks anyway
GrindCulture
Post Thu Nov 13, 2008 5:50 pm
anisotropy wrote:Shouldn't you use the IS gearbox? its a sportier one on most models I think
I dunno about the ratios being different, they're not miles out if they are, but the M42 will fit the M40 gearbox, and difference (if any) will be completely irrelevent.
blackE30indy
Post Thu Nov 13, 2008 7:35 pm
i might need a few stuff of that IS aswell mate
INDY :thumb: :D
Baz666
Post Fri Nov 14, 2008 4:18 am
i`ll have it in my hands today being firday so will take a few pictures and post them on here.
can anyone tell me wheres the best place to get engine mounts from.
Post Fri Nov 14, 2008 10:15 am
BMW
ECP
GSF
Baz666
Post Fri Nov 14, 2008 11:06 am
BMW
ECP
GSF
Thanks Alex, bmw £48.75 each, gsf £6.75 each bloody bit of a difference there ECP never heard of them.
jaistanley
Post Fri Nov 14, 2008 12:10 pm
Any money says the GSF ones will be a solid rubber affair that will hold the engine in the right place. The BMW ones will be hydrolastic affairs that damp vibrations gnerated by the engine much more effectively. The mounts I took off my iS were hydrolastic...
Where are you getting your mount for the iS coilpacks? I bet BMW aren't too expensive at all for a new weld on one. Alternatively you can apparently use the direct fire packs from an M52 engine and do away with them completely. Would be nice and neat.
Good luck dude.
How're you getting on? Any pictures yet? Have you been de-greasing everything. Don't forget my magic formula of 4 parts Kerosene to 1 part fairy liquid mixed till it's a gell. The best de-greaser/cleaner I've ever used.
HTH
robbo86
Post Fri Nov 14, 2008 1:16 pm
Do you mean the coils that plug straight onto the plugs..... Anyone got anyidea how to do this as I am thinking of it when I start on my m42 conversion
Baz666
Post Fri Nov 14, 2008 1:45 pm
here is the doner
other parts will be for sale:
Baz666
Post Fri Nov 14, 2008 2:19 pm
jaistanley wrote:Any money says the GSF ones will be a solid rubber affair that will hold the engine in the right place. The BMW ones will be hydrolastic affairs that damp vibrations gnerated by the engine much more effectively. The mounts I took off my iS were hydrolastic...
Good luck dude.
HTH
ordered them today the engine mounts that is fella 6.75 each not bad i thought from GSF. The coil brackets where about £15 allin from BMW rolled the car down to our jet wash last night covered everything up and washed the engine bay out with TFR i use it on everything good stuff.
for pictures fella
http://www.e30zone.net/modules.php?name ... 98#1266198
GrindCulture
Post Fri Nov 14, 2008 4:41 pm
Are the mounts that are in the iS already fooked? I'd have just used them (and I did...)
GrindCulture
Post Fri Nov 14, 2008 4:45 pm
And as far as using the M54 coilpacks go they're a straight swap for the M42 ones, just need to make up a bracket to hold them in place and re-route the loom.
Baz666
Post Fri Nov 14, 2008 5:02 pm
where can i or who as the m52 coil packs and has anyone got any pictures of this on any e30`s. just thought as the engine was out i might as well change the mounts but will have a good look at them.
thanks GrindCulture
tommy22
Post Fri Nov 14, 2008 5:13 pm
alright barry you got the car then how much did you give the muppet in the end
GrindCulture
Post Fri Nov 14, 2008 5:25 pm
I'm not sure if anyone on here actualy has a COP conversion on their cars, it's on my to do list. Remember it's M54 coils, as found in E46 6pots.
It's impossibly hard to find pics of COP conversions but here's one I stole from someone on M42club.
monkey
Post Fri Nov 14, 2008 5:55 pm
that is well done cop conversion . i had a go at this with m50 coils but couldn't make them fit . i know wot ones to look out for now
Post Fri Nov 14, 2008 9:25 pm
Baz666
Post Sat Nov 15, 2008 10:57 am
tommy22 wrote:alright Barry you got the car then how much did you give the Muppet in the end
yeah hi Tommy, had the change of two but this one had the lowest miles and it was a lot closer and a part history, mileage is only at 112,000 he had the service book and 4 mot papers, bran new wing the the boot. He said it had been sitting there since 2006 fresh petrol and a fully charge battery and she started on the button.
yeah the price, what was it you said he wouldn't take no less then £300 mmmmmmm got it for £200, you know what as well i don't think it would take much to but back on the road, don't know if you had a good look at it when you see it but there's no rust on it anywhere other than where that wing has been changed.
Baz666
Post Sat Nov 15, 2008 11:01 am
GrindCulture wrote:I'm not sure if anyone on here actually has a COP conversion on their cars, it's on my to do list. Remember it's M54 coils, as found in E46 6pots.
thanks fella i`m going to have to search the net for some, does look a lot neater.
Baz666
Post Sat Nov 15, 2008 11:03 am
Thanks Alex
