After reading a few threads today, whats this about using a m20 prop???
Also, after getting the enine back into pos 3, and taking it back out again, i have cut away the sound proofing and gently massaged the firewall(like f#*k)
And did you fit the e34 rad with no real issues?
I have a e36 328 prop but still have my 2 origional ones from the m20 and m30, so input would be helpfull as these are free issue, and I don't have to fork out more for the e36 prop.
Will be back in the morning to hopefully get the engine back in again.
Another question on the exhaust manifolds, I had to remove them again because they were causing a problem on the steering rack, do these need to be modified aswell as I tought they would not be an issue??
