ETA turbo?
Scooter318
I've been running a mostly stock 84 325e since april, and I love it, especially all the torque (She's surprised a few buddies with modified Saabs street racing.) Problem is, I've had my arse handed to me on the highway by everything from a Kia to an E46 with a lady driver! Obviously more power is what I need. I'm contemplating an M30 swap, but dread the wiring, and I don't want to be without my car for that long. I'd prefer to supercharge it, but I'm on a college student's budget so even a used blower is beyond my price range. That leaves one option: a turbocharger. Here in New England, USA, good used turbo/intercooler setups are plentiful, and best of all, inexpensive, and I have access to all the plumbing materials I'd need.
My question is, i've heard that the stock ETA upper end does not lend itself well to tuning. Has anyone tried to turbocharge a stock ETA? My owner's manual says this engine has a compression ratio of 9.0:1 (Though I've seen 11:1 on this forum-- perhaps US and UK versions were different?)
Any advice (either theoretical or from experience) would be very helpful!
- **BANNED**
A useful first improvement would be a stock 320/520 head,same combustion chamber as the eta head but an improved cam...add a 325 inlet manifold and you will still have the torque and around 180bhp as well.The 325 (885 casting) head will work as well,but not quite as well as the 731 (320) casting.After that,stock 325 pistons will lower the c/r to about 7:1 so make turbocharging a possibility,depends on how much you can spare from your student budget
Youth is wasted on the young.
+1 for a 731 320i head
but you might have to import one as there rare over in the states arnt they??
we never got the 325eHas anyone tried to turbocharge a stock ETA? My owner's manual says this engine has a compression ratio of 9.0:1 (Though I've seen 11:1 on this forum-- perhaps US and UK versions were different?)
Gunni
a college student money will not fund this that well.
you need to find a 325i engine + electronics .
That will definitely help you have more fun with the car.
325i conversion shouldn´t cost all that much
731 head and chip should be on his budget tho
Gunni
them heads don´t exist over there.
but a chip is always a upgrade on a 325e
DRIFTBOY
The wiring on an M30 conversion is often the easiest part!
can you not get the 520i thoGunni wrote:them heads don´t exist over there.
Gunni
no they had nothing below a 325i or a ETA
im sure someone on ebay.co.uk will ship you one overGunni wrote:no they had nothing below a 325i or a ETA
and im sure evolve or ant on here will do a chip for it to run right
Gunni
For a eta block and 731 head a 325i ecu will do very nicely,
stock timing will suit the variant well as it doesn´t need added timing like a stock ETA and or 325i.
This setup usually makes about 170hp as the 731 valves are slightly smaller then 885 and the 2.7 offsets that
- **BANNED**
The realy cheapskate way is to remove the eta(200 casting) head and drill out the oilways missing in three of the cam bearings,open up the exhaust ports a little and bung in a stock 325 cam....that should give 180bhp and around 190 ft lb of torque from 2000rpm
for a bit more,get the valve seats re-cut to take 325 valves.
tomson
I thought the US 325e already has the 885 head on it.
Gunni
It does not. It´s got a 200 head,
Super ETA has the 885 head, and ultra crappy cam
tomson
Ah, I see. I have only ever seen one US 325e and it had an 885 head on it so it must have been a super ETA.Gunni wrote:It does not. It´s got a 200 head,
Scooter318
Thanks for the suggestions. Over here we got the E21 320i (I know of one that is under restoration and one that is driven daily in my area), but not the E30 version. Importing a head is a good idea, and I'll look into it.
I bought a 325i parts car a few months ago after reading Andyboy's sticky, but the head turned out to have a crack in it (I got good body parts/glass off it though
I guess it still seems like the M30 conversion might be my best bet, now that I've located a couple 528i's nearby. I'll keep you all posted on what I decide to do, and get a few pics of the car up soon!
Morat
3.5!! If you're going to swap the engine, surely go for the biggest one?
eta
Gummi pm sent
Scooter318
I was just reading Ziggy's sticky, and I see what you mean. Unfortunately I don't know of any E32/34's in the area that could sacrifice their vital organsMorat wrote:3.5!! If you're going to swap the engine, surely go for the biggest one?
