Short Vid of A-Techs Work 2.7 Turbo, Speedo
that must be a 12 second 1/4 mile car I reckon
e30bmlover
- Ac Schnitzer prophet
- **BANNED**
What diff ratio are you using,please?
Youth is wasted on the young.
Thanks Guys
Spec of my 30 is as follows
Engine Spec
Fully rebuilt 2.7 Engine
Alpina C2 2.7 Head.
Polished Crank
All new M50 shells, (Crank, Rods)
New Piston Rings
New OE Alpina Valves 11 34 107 exhaust valve, 11 34 106 inlet valve.
Double valve springs
Turbo Cam
New eccentric rockers
New Valve stems seals, and oil retainers
New spray bar
New High Pressure Oil Pump
44 LB Injectors,
High pressure fuel pump,
Holsett HX45 18 CFM Turbocharger
Wideband controller
Tial Wastegate
Megasquirt
Aluminum Intercooler and Pipework
Polished Rocker and Inlet Manifold
Scorpion Exhaust
Suspension & Handling
White line Heavy duty Anti Roll Bars,
Polybushed Everywhere,
KW Coilover suspension
Refurbed Compomotive MO Alloys, Smoked Chrome Inner / Polished Lips
215/35/17 Yoko S Line Front
225/35/17 Yoko S Line Rears
Strut Braces Front and Rear
Braking
Front
AP Racing 4 Pot Calipers
330 mm Discs
Greenstuff Pads
Rear
WMS 4 Pot Calipers
280 mm Discs
Greenstuff Pads
Drivetrain
5 speed Sport Gearbox
Helix Double Competition clutch
M3 Thrust Bearing
E30 M3 Twin clutched LSD 3.25 Drive 15-90 % lock Ratio
E36 M3 Diff Oil
MTEC 2 Alcantara 370 mm Steering Wheel
Complete Retrim, Black / Silver Inc Doorcards
New Genuine Front wings
Fully Resprayed, Inc Engine Bay
Black Ellipsoid Angel Eyes
Smoked back / side lights,
Black Grill,
Black/silver Carbon roundels
Tinted Windows
Total closure alarm,
Aluminum Pedal set
Parrot Bluetooth kit
Ant could add to the list of the engine spec, as he built it.
She is pretty quick and quite often scary,
but on a nice warm day i don't want to get out of Her.
Thanks again
Gary
Engine Spec
Alpina C2 2.7 Head.
Polished Crank
New Piston Rings
Turbo Cam
New spray bar
44 LB Injectors,
Wideband controller
Tial Wastegate
Megasquirt
Scorpion Exhaust
Braking
Front
330 mm Discs
Greenstuff Pads
Rear
WMS 4 Pot Calipers
280 mm Discs
Greenstuff Pads
Drivetrain
M3 Thrust Bearing
E36 M3 Diff Oil
Black Grill,
Tinted Windows
Aluminum Pedal set
Thanks again
Gary
gareth
that's rapid! nice work!
all on a private runway yeah?
incidentally, how have you got 280mm WMS 4 pots on the rear?
Hi 1an
the whitelines are OK over stock,
but really do need to be Poly bushed for any real effect,
Hi gareth, i originally bought the WMS Kit from kerri for the front,
they did do the trick, but the brakes still felt a bit spongy,
my wife debby then found an Alpina C2 2.7 ON THE BAY,
and won it as a present for me for £1230.
When i picked it up, it had a host of trick bits including the AP 4 Potters,
and Compomotive MO's
I decided to swop over the front calipers etc, and the WMS Kit sat in my garage for a while
A neighbouring Business of mine said that they could make them fit by altering and
machining a new bracket, so i took the old girl down and left it with them,
If you like i can get the plan or drawings of the machining and bracket that they used,
I must say tho, that i havn't felt really any difference by fitting these over standard to the rear,
but they certainly do look trick.
Regards
Gary
@ Fowler, hows the Fridge Dude, is she coming to the Pod ?
Regards
Gary
- fowler
- Boost Junkie
- Contact:
gary i hope it will be ready for the pod has had some more trick bits fitted and needs more boost and i can say i hope it will be there we can ripup some tarmac
glad yours is all good. will have to catch up over a tea at Pod
you coming down the workshop anytime soon ???
EX A-Tech Workshop bitch !!!
gone but not forgotten
gareth
I'd be interested to see how you fitted them actually. the piston area on the rear will now be a long way out, though it's all relative to the pistion size on the front. i suspect you have a heavy rear bias now....
what discs did you use? and do you stil have a handbrake?
GrindCulture
That's one hell of a machine!
Not in E30s any more
Awe-inspiring stuff!
It might be it was, I've seen them sitting over there on full temp.Alburglar wrote:Not very clever. The engine isn't up to temp
- fowler
- Boost Junkie
- Contact:
i can clearly say that the engine is fitted with a tropical climate Stat so it rarely goes over a 1/3 temp in this country so don't be alarmed at this as the car is very well looked after.Not very clever. The engine isn't up to temp
that is quick ! Love it
Damn, thas seriously fookin rapid
ants a absolute legend at wat he does superb to see this monster thats my kind of e30!! how they all should be if u ask me spot on mate fair play enjoy....love the way it boosts up i take it , its mapped to run more boost as it goes up the gears or is that not so? i know a friend of mine had a rs500 running near 500bhp and it was geared mapped , to boost more as it got right up the gearbox thus meaning from 100 on it was unbelivably quick not just scary lol v much similar to that , ( AND A TECH DEPARTMENT I NEED TO CALL YOU TUESDAY WHEN YOUR OPEN ITS MEGA URGENT EXPECT A CALL FROM ME ANT thanks mate ian. )
enjoy
enjoy
bmw 328i sport e36
