where are the is guru's
projectmick
Post Wed Aug 20, 2008 11:19 pm
Ok, I'm in the middle of an m44 conversion at the mo, engine is in and running, only on the existing 316 mounts as a temp measure.
The problem we are having is the sump - it is the wrong way round, and it means we are going to have to modify the anti roll bar, as it was designed to sit round the old sump! 8O
Has anybody else had an issue like this with any other conversions? I want to bring the sump forward so the ARB can fit in unmodified.
Will engine mounts for an e30 is work ok for this? At the moment the sump is VERY close to the floor, having a guard made to counter this, but am concerned about the ARB issue. Time is a bit short, so need to make the right choice in mounts.
Anybody with any info is welcomed!!!!
"Quattro ist fur sissies"
www.mikemasonphoto.mfbiz.com
eko
Old timer
Post Wed Aug 20, 2008 11:23 pm
Cant you just use a M42 sump?
Jon_Bmw
Dangerous when thinking
I think you need a an m42 sump? Was your old 316 an m40? I am not sure if the sumps are the same with the m40 and m42.
Sorry that is not that helpful :)
projectmick
Post Wed Aug 20, 2008 11:28 pm
I hope you can just use m42 sump, but wanted to get that confirmed before I go out looking for one thats all.
M40 sump may be different, I have an idea..... real oem :D
eko
Old timer
Post Wed Aug 20, 2008 11:30 pm
If the M40 sump is the same then OBs(Andy) has one knocking about if you need :wink:
projectmick
Post Wed Aug 20, 2008 11:33 pm
Dammit, can't seem to find it on real oem - I'm being a "special" at the moment! :mad:
eko
Old timer
Post Wed Aug 20, 2008 11:39 pm
Mick ive just checked on bmwfan site and part numbers are the same for M40 and M42 sump both upper and lower pieces.
projectmick
Post Wed Aug 20, 2008 11:45 pm
Thats good news - thanks mate - will have to look at swapping them over if possible then! :D
Where is OB's? Do you happen to know how much would he want for the sump? Will struggle to collect though (having no car!)
happy
Post Thu Aug 21, 2008 12:58 am
you'll need an oil pick up pie off an m40 or m42 aswell as far as i know :cool:
1990 316ia lux
