i've got a 318i cabby, and i'm looking to do a 2.5 conversion from a touring. its already got a discs all round.
i was wondering, what additional parts will be needed to complete the conversion. i.e: are the props different, will the 2.5 diff from touring fit into cabby, etc.
thanks in advance
318i -> 325i cabby conversion
old_skool
Everything you need to know has been covered a hundred times before. The touring and cabriolet drivetrains are the same albiet maybe the final drive (axle) ratio - if you should you use a touring as a donor of course.
Give the search function a try..
